Old 06-27-2016, 06:16 AM   #1
Removing ceiling light covers on A212HW
The bulbs are a bit too bright and I want to see if I can change them. Has anyone removed the ceiling light covers? I would like to know how so not to damage them.
thanks, Bob
Bob
2016 A212HW
rgm0505 is offline   Reply With Quote
Old 06-27-2016, 06:35 AM   #2
Ford Idaho's Avatar
Mine are like this (not led).
Just squeeze it in the middle of the lens and pull down.
Old 06-27-2016, 07:59 AM   #3
Ford Idaho, mine are same shape, but different. I tried squeezing the lens and the body and was not able to get it off.
Hopefully someone who has my light will be able to help.
Bob
2016 A212HW
Old 06-27-2016, 08:09 AM   #4
Mine slide outward from the switch and then drop down. So, I move mine outward from the switch about 1/8 inch and then they will just drop down.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 06-27-2016, 08:13 AM   #5
World Traveler Member
abdiver's Avatar
Mine are the LED ones and its in an Oval lens cover and to remove you just use a knife between the holder and lens and pop it out with slight inward pressure to pop the tabs on the lens.
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 06-27-2016, 08:20 AM   #6
Ford Idaho's Avatar
On mine I can see the tabs that hold in to the housing, this is where I squeeze at, you do need to do so hard.
Old 06-27-2016, 10:34 AM   #7
Thanks everyone. I got it off. It is the lens cover just popping out of the holder.
Bad news - the LEDs are on a circuit board and it may be difficult to replace with dimmer LEDs. I will likely make an insert/filter that will reduce the intensity. This way I can easily remove it to get back to factory specs.
Bob
2016 A212HW
Old 06-27-2016, 10:41 AM   #8
Squeeze and slide away from the center of the fixture. There is a tab, on mine at the end of the rounded end of the cover that has to clear the fixture so it will slide off. It takes a disconcerting amount of pressure, but the covers are made from tough plastic and can take it.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-01-2016, 09:29 AM   #9
HikerBob
I exchanged the original incandescent bulbs that FR put in the fixture with LEDs last year and everything was fine, though the sockets were scorched from the heat of those lamps. They were quite hot. We were having flickering LEDs in one of them last week, so I decided to have a closer look. Right there on the Chinese fixture it says to use 921 lamps (LED) only, but FR had used cheap incandescents originally. It's a good thing we didn't have a fire from those things. I'm replacing the entire fixture now since either the switch has failed or the socket has carbon build-up that's creating the problem.
HikerBob is offline   Reply With Quote
Old 07-01-2016, 10:06 AM   #10
Pickin' & Campin'
You could also consider wiring in a PWM dimmer to dim the light.
Dim when you need it or bright when you need it.
Something like **THIS**.
Days Camped: '15=22 '16=46 '17=30 '18=4
cover, light
