Old 02-19-2015, 03:10 PM   #11
GreenImp's Avatar
Send a message via MSN to GreenImp
This is where I purchased my Lexan Skylight to replace a cracked original...SLOW to ship the product out (he did claim an illness), but EXCELLENT product and worth the wait if possible.
Replacement RV Skylights from EZ Tops World Wide Inc.
Side note FWIW...I went with white (rather than the original clear) to cut down on heat transmitted through and am very happy with the results. There is still plenty of light coming through.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 02-19-2015, 06:48 PM   #12
for those who are not familiar with the roofing panels of an Aframe .. they are basically an inboard layer of thin metal, with a layer of 1 inch foam, then covered in filon or a plastic/fiber like layer, much like the siding of any ordinary rv. There is no structure, just a plastic/metal layer filled with foam, no brackets , no support or any stucture for the windows.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 02-22-2015, 07:53 PM   #13
Slightly off topic, but close,
as I have thought about installing, from scratch, a skylight window in the front top wall of my A122.
Nobody seems to have done this before, and the complications with just a replacement window seem to be many. So, I have been reading with interest, but I would not attempt a new window install until somebody reports about having done it without complication.
Good luck with the replacement, all the same.
mickrock is offline   Reply With Quote
Old 02-23-2015, 11:46 AM   #14
It looks to me as if one had a correctly sized window, it would be simple to use the Lexan bubbles. The bubbles appear to be affixed to the roof with tape and sealed with caulk.
I wouldn't remove one that was in working order, but if one broke, I'd certainly investigate a non factory replacement using some 3M industrial double sided tape, marine sealant and sealing tape. One could of course also use flat Lexan glazing too.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
light, replacement
