Old 08-14-2016, 07:58 AM   #11
chengdave2003's Avatar
That's what I had done also (with an adapter I had machined to allow the use of a drill. See Mod: Front Jack Adapter for a Drill ). It worked fine for a year or so, and then got harder and harder to raise the tongue. I took apart the jack and greased it up, and it helped some, but it ended up stripping a few days later.
Originally Posted by clunk View Post
Thanks for all the help. I'm gonna stick with a manual version as I had the current one fitted so that I could just put my electric drill on it to spin it up or down. If the drill died, I have the hadle stored in the toolbox for true manual operation.
chengdave2003 is offline   Reply With Quote
Old 08-14-2016, 08:38 AM   #12
sorry for your trouble that a bent jack causes for anybody, at any time,...... this may be a good time to also consider adding the Jack-E-Up, ...... there was another thread a few days ago where Jack-E-Up was mentioned and one of its main purposes is to prevent the "bent jack" mishap, ....... no one ever plans for or wants that to happen, but mistakes do happen and usually at the most inconvenient time, ...... with a Jack-E-Up it won't happen again,..... you can't bend it if it ain't there,...............
fella10 is offline   Reply With Quote
bent
