Old 04-10-2012, 10:14 AM   #11
Mostly Harmless
thehamguy1's Avatar
Something else I just thought of, Laura June: the water filter under the sink. If the clear plastic filter housing isn't completely tight or if the large rubber O-ring inside is missing, it'll leak under pressure. There should have been a water filter wrench included with your new owner materials. I didn't know what it was until I emailed the dealer to ask what the white plastic bubble blowing ring was for. Naive, I know.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 04-13-2012, 02:56 PM   #12
Leak
One must be careful when checking the filter housing is properly tightened. You can actually cause it to leak by over tightening. They usually provide instructions for threading on the filter housing. Usually handtight then a 1/4 more.
Hob782
A-Frame interested.
hob782 is offline   Reply With Quote
Old 04-13-2012, 04:27 PM   #13
Mostly Harmless
thehamguy1's Avatar
Good to know. Thanks!
2011 Rockwood A128
60W solar system
Old 04-13-2012, 09:35 PM   #14
Jeep4Two's Avatar
Hob782
A-Frame interested.
So I this same vein (not to detract from the original post). Is there a plate replacement for the domed filter housing? I'd love to regain that space without having to plumb a bypass. I won't put the filter back in as flow was way too severely restricted.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 04-15-2012, 06:40 PM   #15
Rockwood Premier A126
gregory's Avatar
Gary said it wasn't a big deal. He measured and cut a short piece of water pipe, glued two 1/2" couplings to it and gently tightened the couplings to the existing thumb screw thingies that were attached to the filter top using Teflon tape on the threaded ends. He said there was plenty of "give" in the water lines for the modification.
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 04-15-2012, 07:07 PM   #16
gregory's Avatar
Laurajune, this dish drainer, that is made for RVs, works great for me. It fits very well between the sink and wall in our A126.
This photo shows the little drain hole where the water drips back into the sink:
And it stores for travel nicely under the sink. I have more room under there with the water filter gyzmo eliminated. I am very cautious when it comes to leaks. It looks crowded, but is actually lightly loaded with plastic dishes and cups, etc. The fittings and lines on the lower left have only a few hand towels and wash clothes stored on them. I use pencil baskets to keep spices and other things upright and orderly. Never put heavy objects or pressure on/against any of the fittings or water lines.
Hope this helps,
Deb
Deb & Gary
a122
