Old 08-19-2012, 07:26 PM   #1
Rockwood A128S Electric Brakes function ok?
For the past 8 years I have towed a 7500# 25' trailer, Prodigy brake controller. Never had a problem with the brake controller. Sold the trailer and yesterday picked up a new 2013 A128S.
When leaving the dealer's lot I tested the A128S brakes while on gravel. I did not touch the auto's foot brake, only the manual Prodigy activation with Prodigy set on its greatest braking power (level 3). On testing I expected the A128S brakes to lock up and the tire to drag as I crossed the gravel lot. Did not happen, the tire continued to rotate. We hooked up the dealer's tow truck. Same thing. No lockup. We jacked one wheel and pulled the break away switch and with a bit of counterclockwise tire rotation (hand pressure) the brake immediately locked up.
The dealer adjusted the brakes a bit tighter and sent me on my way.
Shouldn't the A128S electric brakes lockup causing the tire to trag when applying full braking power from the controller while towing on gravel?
Thanks,
Neil.
neil.ervin is offline   Reply With Quote
Old 08-19-2012, 09:37 PM   #2
DGrissom's Avatar
Thanks,
Neil.
Mine will lock up if I use the "manual" button on the controller and set the unit up with a high current/braking force. I back them off to avoid lockup -- I don't run them that way. I am using a Primus IQ.
I don't know if this is useful. Again, I have locked them up during set up.
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe" 18 Nights!
2012 Rockwood A128S "Rocko" 200+ Nights!
Nights Camped 2012 - 2017 = 226
Nights Camped 2018 = 0 as of today)
DGrissom is offline   Reply With Quote
Old 08-20-2012, 04:35 PM   #3
My Prodigy 3 does this also.
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
a128, a128s, brakes
