Old 07-11-2018, 02:36 PM   #11
Check to make sure it is seated correctly to start, and not being cross threaded. ie. start over. Sometimes itís hard to start straight because the weight at the other end of the rod makes it want to go in crooked.
mtmurphy56 is offline   Reply With Quote
Old 07-11-2018, 02:48 PM   #12
Pickin' & Campin'
Originally Posted by Sandstone Mike View Post
First time on the Forum and reading a lot of helpful stuff. I have a 2018 Rockwood a213hw and am trying to replace the anode rod on my water heater. Just drained it (found out I don't have to do it so soon, rookie mistake...) I've added 1-2 wraps of Teflon tape to the anode rod threads and after tightening with a socket, a couple of threads still show. I'm afraid to crank on it any more. Is this normal?
Anode rods are tapered pipe threads.
They are not made to be bottomed out so that no threads show.
Upon proper tightening, there will be some threads showing.
As long as it is tight and not cross-threaded you are good.
Days Camped: '15=22 '16=46 '17=30 '18=21
Old 07-11-2018, 03:01 PM   #13
Makes sense. Thanks for pointing that out!
Sandstone Mike is offline   Reply With Quote
Old 07-11-2018, 03:48 PM   #14
wmtire's Avatar
Yes, it will not screw in to the point where the threads dont show. You sound like it's good as you got it .
Just Google suburban anode rods and then look at pictures. You will see exposed threads when installed.
2011 Flagstaff 831 RLBSS
Are people more violently opposed to fur rather than leather because itís much easier to harass rich women than motorcycle gangs?
Old 07-11-2018, 04:47 PM   #15
Will Know the answer on friday.
My A-Frame is in and is in the shop getting prepped.I should have it on friday.Yes i changed my name in here.
CampingMyLifeAway is offline   Reply With Quote
Old 07-11-2018, 04:51 PM   #16
OYO
OYO's Avatar
Someone should make a tool to get these things threaded easier. I worry about cross threading every time. There is just not enough room to get my hand in there.
2016 Rockwood A213HW
2010 Silverado LTZ 4x4 Ext Cab
Craig
OYO is offline   Reply With Quote
Old 07-12-2018, 12:59 PM   #17
I have found over the years that using a deep well socket with a small extension helps when trying to screw the anode in, being careful not to cross thread as others have stated. Start by using the socket/extension by hand and when it starts to screw in, use the socket wrench to tighten up. Hopes this helps.
2017 Rockwood A213HW
2017 Chevy Colorado Z71 4x4 V6
backpacker3 is offline   Reply With Quote
Old 07-14-2018, 04:28 PM   #18
As long as it doesn't leak, you are OK.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
heater, rockwood, water, water heater
