Old 07-22-2015, 07:43 AM   #41
Originally Posted by jeff64 View Post
Those will last about 1 yr. before they leak from my experience. Suggest you look at Valterra W01-7300. Had mine for a couple three years and can be wound up pretty compactly on what you would use for an extension cord
We'll see how long they last when we try them this winter in FL. If they last at least a year, they're not that expensive to replace and I hate messing with the regular ones. I will take the regular with us to FL just in case.
Old 07-22-2015, 03:29 PM   #42
BamaBob's Avatar
I'm with OC. Seems the most onerous PITA tasks I have in packing-up is that %^$@#! hose!
Setup isn't that much fun either!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 07-22-2015, 04:09 PM   #43
If you just lay the hose out straight then coil it up it minds its manners. (unless its really cold outside) You can also find someone to play tug O' war with you grab both ends of hose (not by the fittings) and pull really hard it will help to relax hose.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is online now   Reply With Quote
Old 07-23-2015, 08:47 AM   #44
Fulltime family RVer
We just used ours for the first time and my wife complained about water pressure in the shower. I switched out to our normal hose, but she was mostly done and couldn't tell me if it was better or worse. (She was NOT pleased that I didn't warn her first.. she said the water went cold and then to a trickle. )
Old 07-25-2015, 08:27 PM   #45
Unfortunately that hose has been discontinued by Valterra.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-25-2015, 09:36 PM   #46
Were you using the Valterra W01-7300 or the 5/8" American Specialty Handi-Hose?
Old 07-25-2015, 09:38 PM   #47
American Specialty H10 (I think that's the model #) utility hose.
I plan on switching back to it tomorrow/soon. I think this campground just has crappy water pressure (or there is something up with my pressure regulator).
Old 07-27-2015, 11:07 AM   #48
BamaBob's Avatar
Do you have an adjustable pressure regulator?
Old 07-27-2015, 11:39 AM   #49
Yeah, I bought a Watts one from rvwaterfilterstore.com.
It is showing my pressure as super high- like 80-90psi. I know it isn't that high and when I dialed it back, I cut off water before hitting 60psi.
Old 07-27-2015, 12:40 PM   #50
I have lately run into choke adapters on the end of the hose bib. They don't regulate static pressure but when you open the valve, the water flow is very slow. Then the working pressure drop across my regulator is just abysmal. At that point, I just fill the tank and use the pump.
Tom
2012 Rockwood A122S
water
