Old 11-01-2015, 10:23 AM   #1
Roof assist
Has anyone added roof assist to a Forest River 2015 A122s. Being short and not very strong makes it very difficult.
Jerry Pergande is offline   Reply With Quote
Old 11-01-2015, 12:38 PM   #2
World Traveler Member
abdiver's Avatar
I carry a step stool with me for sitting and standing on and I use it to help me lift the top. And it helps if you have some else to push up on the other handle to start your lift. I have noticed it seems to be getting heaver the longer I own it! Might be my age tho. smile
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 11-01-2015, 01:24 PM   #3
Roof assist
Thanks for the reply. I also use a small ladder. Wouldn't be able to raise the roof without. I notice the new A122s have a pneumatic assist. Forest River must have had complaints.
Old 11-04-2015, 09:37 AM   #4
Your not alone in that and I don't think it is just age. I am tall enough to lift it and make use of my legs instead of the arms for strength. But it has gotten harder. I think the lift springs at the hinge loose some umph over time.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 11-06-2015, 07:29 AM   #5
Yes they do especially if your store the unit in the down position.
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (42)
dts3204 is offline   Reply With Quote
Old 11-10-2015, 09:03 AM   #6
PegKen's Avatar
I had a "roof actuator" installed by a local Forest River dealer who was able to order the parts for a cheaper price than the one quoted to me. Here's the parts that were needed:
Part # 10-22535A actuator set for HS power lift this system includes the
Actuator & brackets ( POWERED )
Part # 10-21448A switch for powered lift for HS
So, to lift the roof now all I need to do is make sure both sides are unlatched and then press the button to lift the roof. However, I need to make sure that the roof is fully lifted or else it's difficult to secure the interior side latches. I also had a battery disconnect installed. The total price for all of the work and parts was $900+. See the attached photo of the part on a unit sent to me by a Forest River rep.
PegKen
PegKen is offline   Reply With Quote
Old 11-10-2015, 06:58 PM   #7
Roof assist
Thanks a bunch. This is just the info I was looking for.
Old 11-10-2015, 09:12 PM   #8
Can you repost a larger picture have the parts numbers but would just like to see it a little better.
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Old 11-11-2015, 12:42 PM   #9
PegKen's Avatar
dts3204
I'm having a very difficult time posting any photos! If you send your private email address to me via my Forest River profile, I'll send close-ups of the actuator that's installed on my unit.
PegKen
Old 11-11-2015, 12:47 PM   #10
PegKen's Avatar
Important info about installation: the directions that came with the actuator needed to be adjusted for my unit. The measurements did not work out and the bottom of the actuator had to be installed at a lower point than where the directions indicated. Make sure whoever installs the actuator on your unit extends the actuator and the roof and marks where it needs to be attached BEFORE they drill any holes in your camper!
PegKen
