Old 10-01-2013, 09:21 AM   #1
FarFromStock's Avatar
Rotating tires?
Do the trailer tires need to be rotated? If so, should we include the spare in the rotation?
Thank you!!
...and...we're camping!!
Glenn & Debbie
2013 Rockwood A127TH (aka Carl)
2012 Ford Raptor
Camping born-on date: 21 July 2012
Nights camped: 2014-3 (so far!!); 2013-16; 2012-2 nights
FarFromStock is offline   Reply With Quote
Old 10-01-2013, 09:35 AM   #2
I really wouldnt go through all the frustration of rotation, not only for the physical pain of doing such a thing, but also the spare wheel is a white cheapie .. and would look terrible on the trailer. Just replace the two that are presently on the camper every 4 years or so ... if they fail a visual inspection, or have had a lot of miles on them. just my .02
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 10-01-2013, 09:40 AM   #3
Resident Masshole
force's Avatar
Short answer: No.
I'm assuming you have two axles. Unless they start showing different wear when you compare front to back (which would indicate an inflation or load problem), I see no reason to ever rotate a trailer tire. Trailer tires tend to wear out due to time and age, not mileage, unlike cars & trucks.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 10-01-2013, 09:46 AM   #4
LKicklight's Avatar
Balance
I would go to the extra trouble of having them balanced, you will be surprised how much they are off. Plus this will extend your tread life considerably.
kickster
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 10-01-2013, 11:30 AM   #5
How far you tow in a year? I've never had a tire that used up its tread. They have all been replaced for aging.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 10-01-2013, 11:41 AM   #6
64c10's Avatar
according to the tires, they should be rotated. I do not include the spare just check for proper inflation. Al-Ko (the axle) dos not care so long as the proper torq is applied to the lugs nuts. check this link for the pdf owners manual for the axle.
2012 A122BH
TV1 2006 Honda Ridgeline
TV2 2014 Chevy 1500 Silverado Crew cab
64c10 is offline   Reply With Quote
Old 10-01-2013, 12:16 PM   #7
Originally Posted by force View Post
Short answer: No.
Abnormal wear is also evidence of an alignment problem, suspension problem, bent spindle/axle or brake problem.
Would not waste the time or effort of rotating the tires.
Old 10-01-2013, 03:06 PM   #8
Thank you all for your input!!
Glenn & Debbie
2012 Ford Raptor
Old 10-01-2013, 03:22 PM   #9
Resident Masshole
force's Avatar
True OldCoot, but I didn't want to scare the OP too much!!
Tom F.
Old 10-01-2013, 04:04 PM   #10
Herk7769's Avatar
I talked to the Goodyear guy about mine. Put over 10,000 miles on my Marathons this year (about 28,000 miles since new 3 years ago) and the front ones are showing an "over pressure" wear pattern (center wear greater than edges). The rears are straight across wear (normal). This means that the front axle is carrying slightly less load than the rear axle.
He suggested "if I wanted" to rotate front to back and keep the tires on the same side. I decided not to rotate them and just put a new set of 4 on at the 40,000 mile point.
HAM CALLSIGN - KC3FFW
