Old 02-28-2016, 04:11 PM   #61
Keep in mind you will void your warranty if you install a hitch. I didn't care and boy did it come in handy hauling my Honda 3000 generator. A frame doesn't need that much generator but $600 for a brand new in the box for 2 years Honda I couldn't resist.
I also added a shelving unit behind the stove by cutting the legs down from an over the the toilet set of shelves. When traveling I either put it on the floor or bed It really gives me a lot of storage room for often used items like a paper towel rack, coffee, cereal, etc. I keep the portapotti under the bench seat during the day & retrieve it for night use only
I do use a WD hitch & pull with a Honda minivan.
royboy334 is offline   Reply With Quote
Old 02-28-2016, 09:04 PM   #62
Bluepill's Avatar
Whenever I think my camper is too small, I just refer to this photo of its interior. Big enough for a (small) party!
2008 Itasca Meridian 37H
Old 02-29-2016, 06:07 AM   #63
Butch Wilson's Avatar
I have a t21qbhw and a Honda 3000. Let's see a picture of your set up. Sounds like something I should check into .
Butch Wilson is offline   Reply With Quote
Old 02-29-2016, 04:25 PM   #64
yep thanks, not concerned on warranty that much -- some storage platform mod to back of camper is high on the list after purchase... will have to find a good fabricator to do it.. with with hitch add-on - platform could have a swing away feature from some use while parked..
still thinking on the generator bit -- 2 honda 2000's in parallel with supplemental dual feed tank versus single 3000 -- lifting and slepping 150 lbs sol is not appealing
I do look forward to lots of use when I retire next year -- both solo and with friends on occassion
thanks
stevetoney is offline   Reply With Quote
Old 02-29-2016, 05:55 PM   #65
Bluepill's Avatar
thanks
I use a Honda EU3000 because I already have it as a Home power back-up. If I were to do it again, I would choose a pair of 2000's. I have to load and unload the 3000 with a winch attached to a portable A frame hoist support.
I could actually get by with a single 2000, because my A/C is only 10K Btu.
Old 02-29-2016, 06:29 PM   #66
How many times are you going to use the coolcat to warm or cool....i never use it ...except for extreme conditions...like Georgia a couple of years ago when it hit 90f in the early mornings.
I have agood quality generator sitting in the basement....never been used....think create a breeze fan...and a excellent quality dual battery system . ...and save your back.
D-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 03-01-2016, 10:26 AM   #67
Bluepill's Avatar
D-mo
Come on down to Florida next summer. Then tell me about A/C use.
Old 03-01-2016, 12:47 PM   #68
mudman2's Avatar
Ditto that😎
mudman2 is offline   Reply With Quote
camper, frame, trailer, a-frame
