Old 05-24-2014, 02:42 PM   #1
Sewer hook up
Combined the kitchen sink and shower plumbing that now goes to a standard 3" sewer hookup with a 3" Valterra gate valve. Can hook to standard campground sewers and still can use the aquacontainer if sewer is not available.
See my album " Sewer hook up" for more pictures.
Rcaldwell0 is offline   Reply With Quote
Old 05-24-2014, 06:24 PM   #2
Nice. How did you connect the stock plumbing to your mods?
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-24-2014, 06:37 PM   #3
I took the sink drain and attached 11/2 PVC to the flex pipe that was original and the wall which the water filter is I went straight down through the floor, put a u-trap and using a 1 1/2 PVC T tied the shower plumbing to this and put 1 1/2 inch to 3" fitting attaching it to the 3" Valterra valve. That valve is then connected to a standard bayonet fitting that the sewer hose fitting goes onto. I will try and get some pictures next time I crawl around under the trailer.
