Old 11-22-2014, 01:14 AM   #21
sheers
Handbuilder, How did you attach sheers under factory brown curtains? Thanks.
mzak is offline   Reply With Quote
Old 11-22-2014, 11:48 AM   #22
handbuilder's Avatar
MLSA3, Did you ever try reapplying your vinyl art from Hobby Lobby? I've had these two up (from hobby lobby) since beginning Summer. The adhesion is not as good as the other companies I've used however the ones from HL are intended to be readily removable, so you'd need to do what Dave's wife did and add a little glue or try what I did and use a little small piece of clear awning repair tape on the edges (or corners) to help it stay in place.
Mzak, I am not a sewing enthusiast - so you may or may not like what I tell you. I attached the sheer curtains with safety pins on the underside of the brown curtains. Haha
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
