Old 05-08-2013, 07:54 PM   #101
wayfaringgirl's Avatar
ko777 -- did your camper come with the inline fuse? Mine sure didn't and I wish it did. That would be a painless solution.
Tom -- I was also going to ask if you're getting the A122 BH or TH. Whatever it is, I hope you get it soon.
Gale
Zoey - Pyrenees/Lab mix
2017 Flagstaff Micro Lite 25BHS
2011 Toyota Tundra
wayfaringgirl is offline   Reply With Quote
Old 05-08-2013, 07:57 PM   #102
ko777's Avatar
Originally Posted by Jsusluvsyou View Post
mFR warranty is good but has changed, just bought a122bh and spoke with FR last week about $100 warranty. It has changed.
Interesting, what is it now? I got this form from them and just mailed it back last week with a cheque:
ko777 is offline   Reply With Quote
Old 05-08-2013, 08:02 PM   #103
ko777's Avatar
Yes as seen in the pic. Too bad you can't use my kiss procedure. If you do any mods to your unit, better call FR and inquire if it voids your warranty. Did you get a 2014 A128S?
Old 05-08-2013, 08:10 PM   #104
Yes -- I just picked up the A128S last week. I got the screen room too
Curious why you have an inline fuse and I don't. Strange thing to change for 2014.
FYI -- I received the same protection plan form you did.
Gale
2011 Toyota Tundra
Old 05-08-2013, 08:25 PM   #105
ko777's Avatar
Excellent...we could compare notes. Also use the kiss on setting up the screen room. I have a routine having this up so my bed stays as is in my trips.
Maybe the fuse container is too expose? I might try to cover this part with something and wrap all the expose wires with electrical tape to give it extra protection from the environment.
And we have the same protection...lol
BTW you have seen mine and I want to see yours please post pics. I'm curious what they changed in 2014 besides the external fuse box.
Old 05-08-2013, 08:28 PM   #106
ThunderRoad's Avatar
Anyone have a contact at FR to inquire about the warranty? Name/Number?
2012 Lincoln MKX
2013 Rockwood A122BH A-Frame
ThunderRoad is offline   Reply With Quote
Old 05-08-2013, 08:39 PM   #107
ko777's Avatar
I post #290 http://www.forestriverforums.com/for...-27602-29.html
Sam allowed me to get it even after 10 days as indicated in the form. I'll look for the phone number and will post later.
Did your dealer mention this option to you?
Old 05-08-2013, 08:53 PM   #108
I paid, I want to say $150, for an additional year of the base warranty that WAS a FR form. In fact I made out the check direct to FR. But I don't remember anything about a lifetime on anything.
I've been trying to find the paperwork without any luck to see if what I did matches this, but it will probably be easier to just see what they have in their records.
2012 Lincoln MKX
Old 05-08-2013, 09:02 PM   #109
ko777's Avatar
Did you get this card, good for 1 year:
I called this number and they gave me FR #574-389-4600, connect to warranty dept and you should get Sam the warranty guy for our model.
Good luck!
Old 05-09-2013, 10:32 AM   #110
jeanette's Avatar
Originally Posted by f1100turbo View Post
Trailer brakes or "breakaway" is powered by the camper OR a remote little battery.
Are you actually talking an "inverter" or the "converter"?
You can mount a battery disconnect outside near the battery.
Use the same gauge wire that the battery cables are.
That's a stupid design to put the battery disconnect inside ?!?!
Why not just pull the main fuse which is located right next to the battery when you want no power on the camper? A lot easier than rewiring. Less opportunity for future issues.
Jeanette Bettis
Wheatland, CA
TV: 2004 Kia Sorento
Rockwood A124
jeanette is offline   Reply With Quote
Old 05-09-2013, 10:36 AM   #111
I'd love to but my new A128S has no fuse on the outside of the camper. Not sure why. Maybe because it's illegal to run without battery power for the breakaway switch, which would be easy to do if you pulled the fuse before driving off
Gale
2011 Toyota Tundra
Old 05-09-2013, 11:33 AM   #112
Refrigerator questions
The refrigerator has a switch for both 12 volt and 120 volt.
Do you ever run the refrigerator on 12 volt?
Do you turn just the 120 volt switch on when plugged into shore power or turn both on?
The dealer did a hurried walk through (I will be having more questions because of this) so I was checking the manual today and it doesn't really say.
Gale
2011 Toyota Tundra
Old 05-09-2013, 11:43 AM   #113
Jeep4Two's Avatar
Never run more than 1 power source at once.
If you tow vehicle has power on the charging pin then you can use 12v while towing, but remember that long periods without the vehicle running can drain the tow vehicle battery of you don't have a battery isolation relay or switch.
Use 120v (12v off) when on shore power.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 05-09-2013, 12:00 PM   #114
Yes it is.
My take on this is that it would be a cause of future issues for me. Namely forgetting to the fuse. Or misplacing it while on the road when I want the trailer battery disconnected. Or falls out if I don't close the holder fully. Of forget to pull it when I get home then can't see whether the battery is connected or not.
For me, the switch is just the simplest way. Marine switches are quite robust and are suitable to leave exposed to the weather for years. The wiring is easy and just requires a few crimp connectors. In the six or so years I had a switch on my Niagara, it never gave me a problem.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-09-2013, 01:58 PM   #115
I'm in complete agreement on this and won't be adding an inline fuse. I can see me misplacing it. For now I've added pulling the inside fuse that will stop power to the interior (was told by my dealer it's the second from the bottom) to my "breaking camp checklist" and will see if that works for now. I'll look at adding a cut off rocker switch near the door or an exterior marine switch later.
Right now all I want to do is get it packed and ready to head out of town and go camping.
Thanks for input from all of you.
Gale
2011 Toyota Tundra
Old 05-09-2013, 02:02 PM   #116
I'd be surprised if there is no inline fuse near the battery line, Ina little rubber weatherproof case. I unplug this during off-season when I'm storing it, put the fuse right on top of the propane tank cover while its in storage (I have covered storage), since I check all the lights and directionally prior to any departure, it's impossible for me to forget the fuse.
Switches, meters and all the extras are nice if you have the time, money and interest in doing all the mods. I'm not interested in that so I try to keep it pretty simple.
2011 A-122
rawlus is offline   Reply With Quote
Old 06-07-2013, 07:31 PM   #117
Tom -- I may wait on this until you get your A122 and see what you find.
The wires going to the battery on mine are red for power/positive and white for ground/negative. This trailer has red for positive as far as I can see.
Do you agree the breakaway switch being hard wired would be better?
When are you expecting your camper to arrive?
Dredging up an old thread here now that I've had an opportunity to inspect mine.
If yours is like mine, it has a circuit breaker on the positive wire, just under the front of the trailer. The breaker is the big red capped thing on the left of the image. The front of the trailer is down.
The wire from the battery runs there but is first split to provide current to the breakaway switch at the bottom of the two connectors, with the red and black wires. The top connector is the return from the breakaway switch that connects it to the blue brake wires.
To add a battery disconnect switch on the red wire, the hot side of the breakaway switch must be cut and attached directly to the red somewhere before the disconnect switch. Even the hot side terminal on the disconnect switch would do.
Always remember to cap off any wires you cut, lest they cause mischief when you least expect it.
I haven't decided on my battery configuration yet. I can see two main options. 1. Having two 12V batteries that are not connected to each other so I can remove one for charging while the other powers the camper. 2. Two 6V golf cart batteries, they will fit nicely on the tongue.
Tom
2012 Rockwood A122S
Old 06-26-2013, 09:00 PM   #118
As far as that fuse outside is concerned, I have a roll of orange electrical tape and when I take it out, I tape it to the top of the battery box. The orange tape is easy to see and if the fuse is there or not. I insisted the dealer cover the wires on the tongue with the same stuff they use on the autos and trucks. Looked good and protects the wires. Would be easy to do yourself and pretty cheap.
hawkeyez is offline   Reply With Quote
Old 06-26-2013, 10:22 PM   #119
How about insurance? I haven't looked into it yet, but was wondering what kind of coverage and approximately how much for a six month comprehensive policy similar to a car policy or will your auto policy include the A-Frame?
gt40 is offline   Reply With Quote
Old 06-27-2013, 10:05 AM   #120
Mostly Harmless
thehamguy1's Avatar
Our camper is covered as part of the policy on the tow vehicle (Farmers Insurance Co.). I think the added premium was something like $32 a year. For road hazards we carry AAAPlus RV.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
