Old 07-24-2013, 08:58 AM   #1
Side-kick. RV-500 help
Would someone shed some light on starting the Side-kick that came with my T12RB? I was not able to get a gas feed, is there gas valve within the camper associated with the Side-kick that overlooked? Bewildered
T12RB-HazelHut
2010 Subaru Forester
Cortland NY
"The only journey is the one within."
ó Rainer Maria Rilke
beyond-there is offline   Reply With Quote
Old 07-24-2013, 09:36 AM   #2
64c10's Avatar
there should be lever on the coupler on the hose coming from the side of camper, this should be in line with the hose after you connect to stove. should look like pic below.
Name:	rv valve.jpg
2012 A122BH
TV1 2006 Honda Ridgeline
TV2 2014 Chevy 1500 Silverado Crew cab
64c10 is offline   Reply With Quote
Old 07-24-2013, 12:14 PM   #3
Jeep4Two's Avatar
Some have reported that the hose is so short that it kinks inside the trailer wall when hooked to the rvq.
Make sure you have a little slack and position the grill in the rail such that you don't have tension on the hose.
Apparently a couple extra inches of hose was too high a cost at the factory.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 07-24-2013, 02:33 PM   #4
There should be a round white plastic cover about the size of a baseball on the camper's side near the RVQ's mounting rail. Open this up, pull out the hose, plug in on the regulator, and flip the gas valve on. Then turn your regulator on , and light er up!
Old 07-24-2013, 02:50 PM   #5
handbuilder's Avatar
Here is a picture of the Sidekick hooked up on the Flagstaff A -Frame, for visual reference
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 07-24-2013, 04:09 PM   #6
Mostly Harmless
thehamguy1's Avatar
If this is the first time you've used that connection, it will take a long time for gas to arrive at the valve. Also, the quick-connect fitting on the hose is designed not to allow gas to flow (even with the valve on) if it's not fully engaged. Make sure it's fully clicked onto the gas grill's fitting, turn on the valve, turn on the burner knob, and hold a lit igniter down near the burner. When the gas finally arrives it should light and thereafter work normally unless disconnected for a long period.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
