Old 05-23-2016, 08:45 PM   #11
Sink Faucet Sputtered then dried up
Thank you all for your comments.
Our trailer is A 102 2012 model.
I have to water lines under the sink at the bottom with values: one is red and one is blue are those the ones to check it they are closed?
I will also check the fuse again- I have # 1 fuse as water pump.
Also the black switch that was in the photo looks like the one we have by the fuse box under the dinette seat.
JoArt is offline   Reply With Quote
Old 05-23-2016, 11:01 PM   #12
handbuilder's Avatar
I have a 2012 Flagstaff. My water pump rocker switch is located at the bottom of the dining room bench seat. Right under the converter door.
You might try running the water with the water pump switch on. Air in the lines will cause it to sputter until the air is pushed out. When the water flows freely and no more sputter. Also remember the water pump is only needed if you are not plugged into city water line.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 05-29-2016, 08:33 PM   #13
It worked!!!! Thank you for all your help.
Old 05-29-2016, 09:31 PM   #14
bikendan's Avatar
Which suggestion worked?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-30-2016, 05:55 AM   #15
Wolverine 1945's Avatar
I was wondering that my self ???
Wolverine 1945 is offline   Reply With Quote
Old 05-30-2016, 08:20 AM   #16
Well I'm not sure if it was a lot of hand waving in front of the pump or what.
Did try these suggestions:
1.Checked fuses
2. Purchased a new 10 amp fuse for #1.
3. Installed new 10 amp in #1.
4.Checked aerator and cleaned it out.
5.Primed the water line with 'city' water. There was water in the tank.
6. Turned off city water and
7. And of course turned on pump switch.
Then the water came on!
I think these were the main things and I was about to use an air compressor to blow out the lines...lucky I didn't need to.
faucet, sink
