Old 05-21-2016, 06:48 PM   #1
Sink Faucet Sputtered then dried up
Filled tank with water...Why did my sink faucet sputtered then dried up? Looked for water pump switch. Is that the one next to the fuse power center? If not where/which one is it?
Thought it could be fuse #1., when removed fused looked okay, though red circuit breaker light #1 did not go on, when fuse was removed.
102A -2012
JoArt is offline   Reply With Quote
Old 05-21-2016, 07:03 PM   #2
Flybob's Avatar
Do you hear the water pump running? The switch should be in the panel with the battery test and tank level gauges. Do you know if the winterizing valve is in the summer position?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-21-2016, 07:13 PM   #3
Head Rambler
The water pump switch is usually labeled as such in the switch panel.
If you didn't have the pump switch on when you pulled the fuse, the circuit had no connection to the battery and therefore the blown fuse light wouldn't have lit.
I don't know of any inline fuses in the water pump circuit.
Did you retry the faucet on city water? If not, the first thing I'd do is check the faucet screen to make sure debris wasn't clogging it up.
Gotta go campin!
Old 05-21-2016, 07:57 PM   #4
In my A122 a-frame, the water pump switch is inside the cabinet under the sink. Water pump and water filter are also there.
At the bottom of the same cabinet are the low point valves, and a valve to the tank. I think I had to open that valve for the water pump to work.
Which A-frame do you have?
Fred W
2014 Rockwood A122 A-frame
Old 05-21-2016, 08:03 PM   #5
Are you plugged in? Is the battery charged? Start at the beginning.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 05-22-2016, 09:00 AM   #6
1.Most A Frames have an on/off switch for the water pump that is located in the cabinet under the sink.
2.There may be two fuses for the water pump: one in the converter unit and one on a wire next to the water pump.
3.There may be two valves on the fresh water tank under the trailer. Both must be closed for the water pump to work properly.
4. If none of above solve the problem, you may have a defective water pump.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 05-22-2016, 09:37 AM   #7
Butch Wilson's Avatar
On my t21QBHW the switch is next to the sink mounted on the panel/compartment that houses the pump ! It is a simple rocker switch.
Butch Wilson is offline   Reply With Quote
Old 05-22-2016, 10:32 AM   #8
Here is the water pump switch on my a-frame . You can see it just to the right of the air conditioning grate. The pump is just behind that panel with a lift up top . What model number a-frame do you have ?
Old 05-22-2016, 07:14 PM   #9
Check the aerator on your faucet. Unscrew it and you'll probably find a bunch of sediment that is blocking the flow.
2015 A122S
CJofWolfcreek is offline   Reply With Quote
Old 05-23-2016, 06:55 AM   #10
Wolverine 1945's Avatar
Right On CJ !!!
Wolverine 1945 is offline   Reply With Quote
faucet, sink
