Old 06-23-2019, 12:51 PM   #1
Socket size
I am new to camping and purchased a Rockwood HE Aframe camper. It came without any jack or lug wrench. Can someone please tell me what size socket it takes so I can buy one to have with me?
frankndeb is offline   Reply With Quote
Old 06-23-2019, 12:54 PM   #2
Multi-Slacker
Can't help with the socket size - do not have your model - sorry
Welcome from SoCal!
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / 2700 lb 2.5" Receiver
CurtPutnam is online now   Reply With Quote
Old 06-23-2019, 01:33 PM   #3
I believe that the lug wench is a 20mm. The jack wrench is a 3/4 in.
cpttimerstraint is offline   Reply With Quote
Old 06-23-2019, 02:58 PM   #4
OYO
OYO's Avatar
On my 2016 A213HW the lugs and stabilizers are 3/4".
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Craig
OYO is offline   Reply With Quote
Old 06-23-2019, 03:54 PM   #5
Iwannacamp's Avatar
As a standard.... 7/16 suds = 3/4 socket and 1/2 studs = 13/16
Unless my memory fails...as it does often
2017 Puma 297RLSS
Old 06-24-2019, 05:34 PM   #6
Junior Old Fart
Just went out and measured the lug nuts and studs on my A122S.
Lug nuts use a 3/4 inch socket,
Wheel studs are 1/2-20 thread.
Stabilizing jacks use a 3/4 inch socket.
LTDunltd is offline   Reply With Quote
Old 06-24-2019, 07:57 PM   #7
Kasual Kamper
No disrespect intended, but you don't own a set of sockets? Or could you borrow one? I would just try each until I found the one that fit. Then you know what size it is for your particular unit.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 06-25-2019, 10:23 AM   #8
You beat me to it. A good SET of sockets is a MUST have, to go along with an otherwise also well stocked toolbox that stays always handy when traveling!
2018 T21TBHW A-Frame
2012 Nissan Pathfinder
tlspencer is offline   Reply With Quote
Old 06-25-2019, 06:30 PM   #9
Originally Posted by tlspencer View Post
...A good SET of sockets is a MUST have, to go along with an otherwise also well stocked toolbox that stays always handy when traveling!
Especially a 9/16" or 14mm socket to remove the roof lift actuator if/when it fails!
2009 Chevy Colorado
2019 Flagstaff T21TBHW
Kenny - WBVPS
SmallRC is offline   Reply With Quote
Old 06-26-2019, 08:54 PM   #10
Since we want the right tools,
let us not forget a breaker bar to use on the tire lug nuts.
And, some of us might even need a piece of heavy duty pipe to slip over
the breaker bar to get enough leverage to loosen the lug nuts.
Quality heavy duty plastic pipe works without being too heavy.
The sockets should be heavy duty quality, as cheap thin-walled sockets
can actually break from high torque.
Some of you might know what I am talking about...
mickrock is offline   Reply With Quote
Old 06-26-2019, 09:21 PM   #11
Gumpster808's Avatar
Socket size
One thing I started carrying is a ryobi 1/2 inch impact wrench. Runs off the 18 volt batteries that go in the blower, work light, etc that we also carry.
Just used in the wifes challenger to change a flat - torque spec is 115 lbs and took them right off no issues.
Much easier than the wrenches and breaker bars etc since Im not getting any younger
Also carry a torque wrench for putting back in if needed.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 06-26-2019, 09:27 PM   #12
chroniekon's Avatar
This covers all the popular sizes. Amazon, Walmart most automotive parts stores.
https://www.harborfreight.com/20-inc...nch-94110.html
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 06-26-2019, 10:03 PM   #13
I found out that the t bar lug wrenches will not work with my aluminum wheels. The head of the wrench is larger than the well that the lug nut sit in. I have to use sockets and a breaker bar. My truck requires 150 lb/foot of torque so I have a really loooong breaker bar.
BarabooBob is offline   Reply With Quote
Old 06-26-2019, 10:22 PM   #14
dannyabear's Avatar
Most 'mag' type wheels require a thinwall socket to fit in the recess, a 6 point socket is recomended; also, beware that the spare may have a differnt size lug nut, learned that the hard way, lol
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 06-26-2019, 11:52 PM   #15
Bluepill's Avatar
My travel kit for stabilizer jacks and lug nuts:
