Old 05-06-2013, 10:35 AM   #1
Solar
Hubby had this brainstorm last night...Would it be possible to connect the solar panels to the trailer through the plug that connects to the TV? We are picking up our A122BH Wednesday. With the PU we had, we installed a 'cigarette lighter' connector to charge the battery with the solar. If his idea is possible, we wouldn't have to 'install' anything, just plug into the existing connector. Any advice?
51 hours to pickup....
Carla
2014 A122BH
18 Trips
47 Nights
20 Sites
6655 Miles
Carla is offline   Reply With Quote
Old 05-06-2013, 10:41 AM   #2
If I remember correctly a friend of mine did that to keep his batteries charged. You just have to figure out where the wires go.
Pipeman is offline   Reply With Quote
Old 05-08-2013, 03:59 PM   #3
this strongly depends on the strength of your solar panel. Wiring it through a cigarette lighter is probably for a much smaller panel. What size (in watts) are you looking at hooking up ??
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 06-01-2013, 10:58 PM   #4
d-mo
we have three 15 watt panels (I think that is right, harbor freight purchase)
Carla
2014 A122BH
18 Trips
47 Nights
20 Sites
6655 Miles
Old 06-01-2013, 11:58 PM   #5
Batts-toy's Avatar
I also have the 45 watt solar unit from Harbor Freight. You will need to be very careful as to what you hook up to, I am not sure what 'wires to the TV you are referring to. Notice the wires from the solar panels that can clip to the battery posts and how small they are, these small wires handle the current from the panels (45 watts is not a lot of juice) if the plug you are referring to is the pigtail that connects your TT to your TV while traveling and you make sure you wire negative to negative and solar positive to the positive wire that goes to charge you TT battery I personally think you would be ok connecting it this way. Like I said though you or Hubby needs to be sure you are getting onto the correct wires or you could get some electrical shorts going. Good luck.
Dale
2013 Wildwood T26TBSS
2013 Tundra
Batts-toy is offline   Reply With Quote
Old 06-03-2013, 05:34 PM   #6
ThunderRoad's Avatar
Make sure to have a charge controller in there or you can overcharge the batteries and that could be "bad".
2012 Lincoln MKX
2013 Rockwood A122BH A-Frame
ThunderRoad is offline   Reply With Quote
solar
