Old 07-24-2012, 07:24 AM   #11
FarFromStock's Avatar
Great videos!!!! Thanks for sharing!!
...and...we're camping!!
Glenn & Debbie
2013 Rockwood A127TH (aka Carl)
2012 Ford Raptor
Camping born-on date: 21 July 2012
Nights camped: 2014-3 (so far!!); 2013-16; 2012-2 nights
FarFromStock is offline   Reply With Quote
Old 07-27-2012, 12:15 PM   #12
As promised earlier, my equipment list follows.
100W Solar Panel cost $299 from EBay seller dab.soalr. I could not find any US made flexible panels this thin so I had to purchase a Chinese panel. The panel was shipped from California. There is no current US listing for this panel. However, this same panel is available from his UK location.
Solar Converter (Solar Converters Inc PPT 12/24 - 10) $125 from solarseller.com
10' of 10 gauge zip cord: Zip Cable Cord
Watts-Up power meter: Watt's Up Meter by Power Werx
Powerpole connectors and mounts from powerwerx.com
Cigarette Lighter Socket: Amazon.com: Blue Sea 1011 12V DC Socket: Automotive
3M double sided outdoor tape: Amazon.com: Scotch Permanent Outdoor Mounting Tape, 1 Inch x 450 Inches (4011-LONG): Office Products
3M 1" Extreme Tealing tape: Extreme Sealing Tape, W 1 In, L 18 Yd - Packaging Tapes - Tapes - 4YLY7 : Grainger Industrial Supply
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 07-27-2012, 01:33 PM   #13
ThunderRoad's Avatar
Was the solar panel a single 100w panel? I see that ebay store has a 100w, but it looks as if it's 2x50w bundled together.
2012 Lincoln MKX
2013 Rockwood A122BH A-Frame
ThunderRoad is offline   Reply With Quote
Old 07-27-2012, 01:58 PM   #14
The panel is a single 100W panel.
From my original post:
The panel in the UK: UK Stock UK Ship 100W Semi-Flexible Mono Solar Panel for DIY Car,Boat,Carvan | eBay
You could email the seller to see if he will be getting more US stock.
Dave
Old 07-27-2012, 02:44 PM   #15
Got mtn bike?
ddavis662's Avatar
Great set up!
Is your solar panel charging a separate battery?
Or did you just bypass the existing interior 12 volt system when you wired the cigarette lighter and power plugs directly to the battery?
ddavis662 is offline   Reply With Quote
Old 07-27-2012, 03:07 PM   #16
Originally Posted by ddavis662 View Post
Great set up!
I only have one battery setup (two 6v batteries in series). They feed the trailer just like original battery.
I bypassed the factory wiring and ran new 10 gauge wiring directly to the batteries for the internal cigarette lighter and power plugs. I did this because I wanted a direct to battery connection for my ham radio (20 amps) and soon to be purchased 12V compressor fridge (5-6 amps). This frees up the factory wiring for running interior lights, Fantastic fan, TV, radio ...etc.
Dave
Old 07-27-2012, 03:33 PM   #17
Got mtn bike?
ddavis662's Avatar
Dave
Cool!
I was just wanting to make sure that I wasn't missing something.
Old 08-04-2012, 01:15 AM   #18
BelgianSquiggy's Avatar
Excellent! Now I have to start another jar of savings! Thanks for the info.
BelgianSquiggy is offline   Reply With Quote
Old 09-26-2012, 11:22 PM   #19
Well I have been toying the idea around to do the solar panel install. I'm debating if I should mount a panel on the roof, or have one that I can set up on the ground to angle towards the sun.
Long story short, for me to park easily where we normally camp, the truck faces north, and the solar panel would face north also on the roof. How efficient will the panel be if it is a sunny day, but it is facing away from the sun? Most of our camping trips are about three to four days, and I would think that 100 watt panel would be good. 5 amps give or take in full sun, but what about my situation?
We will be boondocking for three days towards the end of october, and we will have to use the furnace. 9000 ft elevation, and about 25 degrees at night. But we will have the radio, lights(still have to order LED lights, suggestions?) on for a longer time seeing that the sun will set alot earlier so battery usage is a concern. I would imagine that if the panel could produce 2.5 amps to compensate for the furnace, we should be ok, but unfortunately I can't find anything about solar panel output when the panel is facing away from the sun.
Old 09-27-2012, 08:06 AM   #20
Solar ...
This strongly depends on the type of charge controller you have.
I have basically the same system as the daveinpicterington, about 80 watts, but with another 30 watt panel dedicated to charging a Xantex/inverter product.
I have not mounted my panels, but use them with 25 ft of cable to find the sun, as these panel really work, only when the sun is fully on them. My charge controller will only allow charging when the panel is fully in the sun, and the battery bank is lower than the output, volt wise. Once the panel is out of the sun i get some charging effects, not nothing compared to the digital pulse blasts of 14.4 volts every 15 or so secounds. Out of the sun i can push in, but who knows what amp level that would be.
We live and camp mostly in Ontario, using our provincial parks as go to spots. Most of these are quiet and shaded, therefore the setup has to remain off the trailer.
hope this helps ... d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
a122, solar
