View Poll Results: use Solar Power
Yes 7 70.00%
No 3 30.00%
Voters: 10. You may not vote on this poll
Old 10-11-2015, 08:57 PM   #1
Rockwood A192HW Camper
Solar power connection to A192HW via the Solar ready feature - what is this?
Were getting it ready for BoonDocking (no shore power). heard there is a solar ready connection near the front by the vehicle power cord?
anyone know about this? know where it is and what it does?
Dealer say connect solar panel and power manager direct to the battery.
any recommendations on size of solar panel and controller?
want to use this to only power the 12v features of the system e.g. charge battery, to run DC appliance e.g. lights, refridge, radio, etc.
Anyone else thinking about this and have a tried and true solution?
--Ron
ronmon is offline   Reply With Quote
Old 10-12-2015, 02:01 AM   #2
DanM-AZ's Avatar
Solar ready? Yeah:
Solar Ready RV Solar Kits - Zamp Solar
Did you say boondocking solar A-Frame?
200 Watts solar on my A-Frame
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 10-21-2015, 07:13 AM   #3
What, exactly does the "pre-wire" mean? Is it just a pair or wires run to the battery that happen to go through the sidewall and look pretty?
johnm1 is offline   Reply With Quote
Old 10-21-2015, 09:13 AM   #4
DanM-AZ's Avatar
For A-Frames, that's exactly what it means. You will need an external solar charge controller which is usually mounted on ground-mount solar panels, specifically from ZAMP:
http://www.forestriverinc.com/brochu...psolarinfo.pdf
Bigger RVs with solar connections on the roof, may already come with a solar charge controller installed from the factory. In that case, all you need are the solar panels.
Dan
Old 10-21-2015, 04:17 PM   #5
If you plan on using that prewired connection, check the polarity with a multimeter. I had to make a special connection since Z-amp and my Renogy suitcase panel are reversed from each other.
2015 A122S
CJofWolfcreek is offline   Reply With Quote
Old 10-23-2015, 10:35 AM   #6
handbuilder's Avatar
Here's our solar set up. This monocrystalline panel efficiently works to charge the battery during the day. Its for the basics: recharge the battery, charge my phone and small electronics. We have LED lights in the trailer but we tend to use small battery and solar lanterns when dry camping.
The 12v volt meter helps to keep an eye on how much battery life is left. It's connected to the floor runway light switch, so it can be switched on and off and not drawing power all the time with its read out.
(Don't know why my photo flipped sideways. Don't know how to fix it but it gives the general idea)
ID:	92577   Click image for larger version
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 03-13-2016, 05:16 PM   #7
ccamper's Avatar
2015 A192HW 100w solar panel. 30amp charge controller mounted next to breaker/fuse panel in dinette area. Works great.
ID:	101838   Click image for larger version
ccamper is offline   Reply With Quote
Old 03-13-2016, 11:07 PM   #8
World Traveler Member
abdiver's Avatar
I installed a 100 watt solar panel with controller and cable for $180 with no pre-wire. All I did is buy a battery post connectors at home depot and $129 grape solar panel and 20 controller that will support up to 3 panels and 50 feet of wire that I cut in half for 25 feet of movement for my panel.
Name:	Half Moon Bay, Calif.jpg
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 03-16-2016, 03:35 PM   #9
1A Camper's Avatar
refridge uses so little propane when running and would require so much solar and battery not sure it would be worth it on 12V when dry camping. I have 2 34 watt panels most of the time I can get by on one but some times need 2 if a little shaded.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 03-20-2016, 05:46 PM   #10
Solar set up
Thanks for the info Abdiver, I am a total newbie, I saw the grape solar panel at costco. Can you link to the 20 controller and post connections you use so I can see them? Are you happy with your setup and would you do anything differently?
Bend5729 is offline   Reply With Quote
power, solar
