Old 01-02-2019, 03:34 PM   #1
Spring replacement for A122 Premier
I have a 2012 Rockwood Premier and noticed its quite hard to put up now. Are there springs within those metal tubes I see at each corner? Are they hard to replace (as in me doing it). Are there any videos to help? Anything you can offer would help.
wcoloradokid
wcoloradokid is offline   Reply With Quote
Old 01-02-2019, 04:18 PM   #2
MontyPP's Avatar
Goingnowherefast has a youtube video that shows him replacing the springson his ALiner. There are other ones there as well as I recall.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
MontyPP is offline   Reply With Quote
Old 01-02-2019, 06:20 PM   #3
Out of curiosity, did you store the A-frame with the roof in the up position or down position when not in use? It is recommended, if possible, to keep the roof up. But have not seen any verified data how much it helps, or not.
Here is a video by GoingNoWhereFast showing spring replacement on an Aliner. I would think torsion bar replacement would be similar. Aliner Aframe Roof Spring Replacement and Bungee Installation
Here is a thread on this forum regarding spring replacement for Aliner. Again, it might be similar concept for a Forest River torsion bar. http://www.forestriverforums.com/for...ar-112916.html
2016 Coachmen Viking Legend 12RB A-Frame
2015 Jeep Grand Cherokee Summit w/Tow package
Alben is offline   Reply With Quote
Old 01-02-2019, 06:36 PM   #4
Store it in down position, concerned that high winds may tip it over? No chance in down position?
Old 01-02-2019, 10:50 PM   #5
MontyPP's Avatar
I live in NE Ft Worth, TX. I store mine up, with stabilizers down and facing south. No problems in two years. I does have the house behind it.
Flagstaff T21TBHW
Old 01-03-2019, 02:20 AM   #6
Torsion bars?
Looks like I have torsion bars? A-liner video does not help since they have springs. Anyone know of video on how to replace bars?
Old 01-24-2019, 09:13 PM   #7
You might also
check the bungee cords, since they interact in the process.
And, they do wear out.
Good luck!
mickrock is offline   Reply With Quote
Old 02-16-2019, 10:48 PM   #8
My fix
Had same issue with my 2014 A124s.
My front bulkhead where the torsion bars connect into the center is a 1 1/2in board that runs top to bottom and is glued to the floor. YES glued in place. Thats were it came undone thus when lifting the roof there wasn't much energy from the torsion bars.
I'll post some pictures tomorrow. Used 6in pressed steel shelve brackets to keep that torsion bar pocket bar in place. Inside looks great. The storage compartment not so good but I don't sleep in there.
Fazzy
Fazzy is offline   Reply With Quote
Old 11-13-2019, 03:04 AM   #9
Broken Torsion Bars
Rockwood A122: Both of the Torsion Bars, not springs, broke in the corner bend area for the rear roof. Almost impossible to open camper. Needed help and 2x4s. Are there any recommended sites for purchasing replacements and are there any videos. I have not found any yet.
Stored in down position. Can only think freeze/thaw cycle would do that.
Glnbo
glnbo is offline   Reply With Quote
a122, replacement
