Old 08-05-2014, 01:52 PM   #11
Originally Posted by RhoZeta View Post
Very nicely put, Fred.
I will add tho that 12V alone will not run a fridge. It HAS to have either 110V OR LP to cool. The 12V only runs the control board.
Unless you have some hybrid 3 power source fridge I have never heard of before.
Folding FR campers, like the OPs, that will fit in a standard garage, come with a 3 way fridge. that will "run" on 12V alone. The quotes are there because the 12V setting is really a sustainer mode while towing and will not keep it as cold as it should be for long.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-05-2014, 02:06 PM   #12
GalsofEscape's Avatar
Yes, the three way fridges do run off all three power sources.... my manual lists 4 Dometic models that are three way and will run in DC mode. I travel down the road in DC mode all the time. But it can drain the battery if you are not charging the battery through the pigtail connection on the tv....do not take a long meal break ;-).
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 08-05-2014, 02:13 PM   #13
Bob P's Avatar
Ohio State Law
Seems many states have laws about the storage of propane. Might be good to check with your home insurance as well. A persons judgement, may not override the law. I am going to take a guess that there are good reasons for these laws.
Ohio law for storing propane tanks.
(b) 3809.10.2 Storage within residential buildings. Storage of cylinders within residential buildings, including the basement or any storage area in a common basement storage area in multiple-family buildings and attached garages, shall be limited to cylinders each with a maximum water capacity of 2.7 pounds ( 1.2 kg) and shall not exceed 5.4 pounds ( 2.4 kg) aggregate water capacity for smaller cylinders per each living space unit.
2015 Flagstaff T12TST A Frame
2011 Toy. Sienna w/tow prep
Bob P is offline   Reply With Quote
Old 08-05-2014, 02:37 PM   #14
Infractee
There ya go, that is one I have never heard of before!
I would think it would not be a bad idea for all RV fridges to be able to do this then?
RhoZeta is offline   Reply With Quote
Old 08-05-2014, 03:30 PM   #15
Paradise has arrived!
Paradise115's Avatar
I think the operative words are "attached garage." And yes, you store gas and other flammables in the garage. But I don't think that means you should necessarily add to the risk. But that's just me. A great discussion though.
Paradise115 is offline   Reply With Quote
Old 08-05-2014, 03:33 PM   #16
The small fridges in pop-ups and A-frames draw 6-8 amps on 12V DC - and even then, as stated, they do not cool nearly as well as on AC or propane. It would not be practical to run significantly larger fridges on 12V. Freezers are out of the question.
Fred W
camping in Colorado - 4 weekends this year so far
2014 A122 (stored in garage, ready to go except for food and clothes)
2008 Hyundai Entourage (minivan) with Equalizer 600/6000 WDH/anti-sway
Old 08-05-2014, 04:13 PM   #17
Attached garages are the norm in Colorado for houses built in the past 40 years - winter weather makes that sensible. Many/most of us do not have separate outbuildings like sheds; in newer construction garages tend to be at the front of the house and quite close to the street to minimize snow clearing.
So compliance with a law like Ohio's - if it were to exist in Colorado - would be impractical. I would be taking on more risk by storing a propane cylinder out in the open, where the temperature swings are much greater than in the garage (my insulated, unheated, attached garage doesn't go below 35 degrees F, so I don't need to winterize the water system or remove the batteries from the camper). Outside, an LP tank is subject to the elements, including intense sunlight in the summer. The chances of the propane tank (or a gas can for that matter) venting itself because of pressure differentials are far greater outside than in the garage.
Again, my engineering background and experience tells me that the steel propane cylinder in good shape with the tested metal valve shut (and red on the regulator pressure) is a whole lot less likely to vent than plastic gasoline "cans" with snap on plastic caps (or gas tanks on power yard equipment).
If you want to remove your LP tanks before storing the camper in the garage, I have no issues with that. I would think that you would want to change the tank mounting and plumbing to something simpler to disconnect and remove than the standard camper setup. It still won't be as easy as a battery disconnect switch, but the tank tie downs especially could be made a lot quicker to release/fasten.
Fred W
2014 A122 stored in the garage, ready to go except for food and clothing
4 weekend trips to date this year, Labor Day is next at Ridgway.
Old 08-05-2014, 08:02 PM   #18
Jeep4Two's Avatar
I remove my tanks, just a general precaution in the event of a leak. I use my garage for my car, which would be an ignition source in the unlikely case of a leak. Just peace of mind for me.
I happen to have a storage shed to store them which presents another potential enclosed area issue, but no electrical there and leaky tanks would be quickly noticed on entry by the odor.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 08-05-2014, 09:57 PM   #19
Our garage also houses the water heater and boiler. They are at the rear of the garage. I keep my BBQ tank near the overhead door and back my camper in. Probably my most significant precaution is to store my flammables in a cabinet. The propane bottles are always turned off. Just use common sense without going overboard. Run a simple "risk assessment". Keep the bottles away from heat. In the event of a garage fire, you vehicles gas tank will be the first one to go.
2009 Toyota Tacoma V6 crew cab 4X4 V6 TRD
2014 Flagstaff T12RB
bobrapp is offline   Reply With Quote
Old 08-05-2014, 10:17 PM   #20
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I personally do not store propane inside the garage or any enclosed space, because if something goes wrong it will not just burn it will explode.
I've seen it happen in a barn many years ago, you can (hopefully) run from a fire but never from an explosion - period.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
propane, safety
