Old 08-14-2014, 06:03 AM   #21
MinneweeseMI's Avatar
Here's another thread about this:
Coleman stove hookup
I ended up putting a drop-in stove in a frame so it doesn't have to hang on the side rail, but quite often we use it on the side rail table.
Mark and Dawn
Michigan
2014 a122s
2014 Tacoma Double Cab
Our YouTube Channel
Days Camped 2017: 106
MinneweeseMI is offline   Reply With Quote
Old 08-14-2014, 06:24 AM   #22
Engineer of Crazy Train
ChooChooMan74's Avatar
There is someone who made their own stove for the outside. I hope I can find it. It was either here or another forum....
Found it. Look through all his pictures, as there are a few pictures of it.
http://s1330.photobucket.com/user/br...89b7b.jpg.html
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 08-14-2014, 10:19 AM   #23
Originally Posted by pgandw View Post
My 2000 Coleman Westlake had an external gas disconnect that bypassed the regulator up at the tanks. I got an extension hose to run our Roadmaster grill from the camper gas line instead of using the small bottles.
My Niagara had the regulated high pressure line and the nice outdoor stove. But I too really find the portable bottles so easy that no mods are in the works for me. And the Coleman stove puts out far more heat than the old attached stove, so the coffee water boils much faster, which is what is really important here. I think of it more as a fall back in case the small bottles "run dry."
Since I have the outside shower on the A122 (never used as a shower so far), I am looking to mod that a little to use as a hot water dispenser for dish washing/cleanup instead of a kettle on the stove.
I set up a dish washing station by the outside shower using a small folding plastic table. I keep a small bottle of soap and a scrubbie in the shower housing all the time. Post back when you get your mod worked out.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-14-2014, 06:56 PM   #24
Originally Posted by bobrapp View Post
I too did not like the outdoor grill and had my dealer replace it with a 3-burner stove. Both 2 and 3-burner stove are available from FR. The are used in the lower end popups for use indoors or out. My wife loves it as she does not stink up the camper when doing heavy duty cooking.
See:
http://robertssales.com/options/stoves.html
This one looks to be a regular Suburban drop-in stove dropped into some plastic carrier that can connect to the mounting rail. A similar setup could probably be made out of wood or aluminum or whatever material with the same drop-in range cooktop.
2011 A-122
rawlus is offline   Reply With Quote
Old 08-15-2014, 10:51 AM   #25
There's a lot of information here, thanks!
I think I've decided for the moment to just use my coleman stove with a propane bottle. For just boiling water and cooking things that aren't messy, I'll just use the indoor stove.
I actually wouldn't mind picking up one of those stove/oven combos so I can bake things when away from power!
2014 Rockwood A122BH
2017 Nissan Pathfinder
bensinc is offline   Reply With Quote
Old 08-15-2014, 01:51 PM   #26
I came to the same conclusion and use my trusty old Coleman stove with a bottle. But, I keep thinking that someone should come up with a stove that will use our trailer rails and connection. Shouldn't they?
Tinsu is offline   Reply With Quote
Old 08-15-2014, 02:43 PM   #27
Evereddie's Avatar
But if they did you wouldn't want to trade up to the camper that has an outside kitchen with stove.
Evereddie is offline   Reply With Quote
Old 08-21-2014, 05:22 PM   #28
yea .. well i just kind-a upgraded...
we are kinda outside campers (really only use the aframe to sleep in... except on really rainy days) .. so i just grabbed a coleman propane tree and a couple of 8 ft hose extensions ...
I quess around 100 bucks did the job ... but no more 1lb bottles ... and a three way hookup for both the weber Q, 2 burner stove,. and a lantern ...
hope this helps .. d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 08-27-2014, 03:46 PM   #29
Just picked up the 206 carry out stove. Works great, can be on the rail or on a small table. If you use it on the rail you need to open it first. With My hose extension I can move it up to ten feet from "Shiny" and it sits flat. A big improvement over the Bar B que. My dealer ordered it and I had it about 5 days later. Still had to do that 200 mile round trip but I think it was work it.
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (42)
dts3204 is offline   Reply With Quote
Old 08-28-2014, 05:46 PM   #30
kkin's Avatar
Did you go to Springfield, Pana or Rockford ( or d:none of the above).
kkin is offline   Reply With Quote
door
