Old 07-01-2015, 08:09 PM   #1
Suburban furnace igniting sporadically
Hello from Maine!
our vacation in our a122s at Acadia is going well except our Suburban NT-26SEQ is acting up. We are running on 20 amp service. Propane is fine (water heater and stove working well).
The furnace doesn't try to ignite most times, but every 7-8 times it "clicks" and fires up.
I've searched forums for anyone with this same sporadic issue, but haven't found this exact problem.
Anyone with any ideas for a possible campground fix? Keep in mind I am the least handy person around, but I do have some tools and can kick the trailer pretty hard.
mmanley1 is offline   Reply With Quote
Old 07-02-2015, 02:11 PM   #2
I had an issue with my furnace on a truck camper. Furnace was an Suburban or Atwood, cant remember but similar symptoms as your. Replaced my propane regulator that connects to the tank and fixed the issue.
2015 Rockwood A122SXR
2006 Toyota Tundra Double Cab 4x4
biscuit72 is offline   Reply With Quote
Old 07-02-2015, 02:26 PM   #3
TURBS's Avatar
Possibly Cob webs in the flue, blow out flue with compressed air.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-02-2015, 02:45 PM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
I'm not sure I understand: do you want the furnace to light? or is it self ingniting? The reason I'm asking is that it's July: why do you need a furnace?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 07-02-2015, 02:49 PM   #5
waiter21's Avatar
I'm not sure what your symptom is, Please repeat.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-02-2015, 02:58 PM   #6
Crockett's Avatar
Originally Posted by mmanley1 View Post
Hello from Maine!
sounds like the sail switch is hanging up or fan speed is too low. can you do anything to boost 12v ??
Crockett is offline   Reply With Quote
Old 07-03-2015, 12:19 PM   #7
furnace
I had a similar problem
Ended up the igniter was crimped onto the bracket and had loosened up and moved enough so the spark didn't always catch the gas. I removed the igniter, moved the sparked forward and recrimped it. Worked fine.
RussPastuch is offline   Reply With Quote
Old 07-04-2015, 06:28 AM   #8
VaJim
Furnace
The fan must start first to satisfy the sail switch before it will ignite. I had to replace my fan motor (two years old) it would not lite sometimes.
2010 Ram 1500 Quad 4X4 5.7L
2012 V-LITE 30WFKSS
VaJim is offline   Reply With Quote
Old 07-04-2015, 06:59 AM   #9
Could be the igniter is loose and loosing electrical connections or igniter is not positioned correctly. See page 29 of attached.
Old 07-04-2015, 01:56 PM   #10
Dsfast's Avatar
Thanks old coot we don't have a furnace Manuel and I can save this attachment and now I have one
Dsfast is offline   Reply With Quote
furnace, suburban
