Old 05-22-2016, 05:43 PM   #11
Have you cycled the thermostat completly off and on multiple times? It will make only a limited number of attempts to fire up before timing out. You will then have to cycle the thermostat to get it to attempt to start again. This is sometimes necessary if there is air in the line. Might take several attempts to purge the air.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 05-22-2016, 05:53 PM   #12
ccamper's Avatar
Originally Posted by jrmorris View Post
Had a problem with my furnace not working and had a RV mobile repair man check it out and he replaced 2 sensors that are located on the back of the furnace and solved my problem When got back in town went to my dealer to submit a warrenty claim and they informed they are having a lot of problems with the sensors on Suburban furnaces. Doing the same fix I had done.
Thank you, I think that's the 1st place on the furnace I'll check. I appreciate the info.
ccamper is offline   Reply With Quote
Old 05-22-2016, 05:54 PM   #13
ccamper's Avatar
Originally Posted by CedarCreekWoody View Post
Have you cycled thd thermostat completly off and on multiple times? It will make only a limited number of attempts to fire up before timing out. You will then have to cycle the thermostat to get it to attempt to start again. This is sometimes necessary if there is air in the line. Might take several attempts to purge the air.
I don't think that's the case. The furnace does nothing, like it has no 12V power, but it does have power.
Old 05-23-2016, 11:37 PM   #14
handbuilder's Avatar
Is the propane on?
Did you change the mode to "Furnace"?
(Good for you to remember to put it on auto)
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 05-23-2016, 11:56 PM   #15
ccamper's Avatar
Originally Posted by handbuilder View Post
Is the propane on?
Propane is on. Even lit the stove to make sure. My Dometic digital thermostat has four modes: Fan, cool, furnace, and heat pump. Each mode has a green LED next to its label indicating which one is selected. I select furnace, turn the thermostat temperature up above ambient, and nothing happens.
Old 05-24-2016, 07:43 AM   #16
Head Rambler
Has it ever worked?
If not, there may be a switch on the unit itself that's turned off. Seen a few reports of that.
Gotta go campin!
Old 05-24-2016, 08:02 AM   #17
ccamper's Avatar
Originally Posted by Bama Rambler View Post
Has it ever worked?
I purchased April last year. When I got it home, I tested everything and it worked then.
Old 05-24-2016, 09:02 AM   #18
Head Rambler
And you checked at the furnace and there's power at the fuse, but none at the furnace?
Sounds like a wire loose somewhere.
Gotta go campin!
heater, suburban
