Old 04-29-2016, 12:29 PM   #11
Coachmen Clipper Fan
PFLOYD75's Avatar
So as I live in an apartment complex and can't really have the TT there and plugged into any electricity to cool down the refrigerator for a day prior to leaving for a trip, I plan on going to where it is in storage, turning on the propane and insuring the refrigerator is setup on "AUTO" to run via propane and then going back to hook up the next day to the TV and hitting the road. This should work well as an alternative to early cooling down too, right?
Thanks, All!
Mark R. Wagner
PFLOYD75 is offline   Reply With Quote
Old 04-29-2016, 12:48 PM   #12
Thanks, All!
Yes. Just be aware the refrigerator uses a small amount of 12v (even when on propane) for the control board.
A day or so won't matter to the battery but don't leave the storage area and shut of your battery cut-off switch as you typically might. The refrigerator will quit.
Days Camped: '16=46 '17=30 '18=51 '19=4
Old 04-29-2016, 02:03 PM   #13
All of the articles I've read on the subject say not to travel with the gas on due to fire risk when stopping for fuel and at other times. I've had a personal experience with a broken spring on the trailer, which resulted in a shredded tire which somehow broke a propane line. Fortunately, someone saw it happen and signaled me to stop. I turned off the tanks before a fire started. These articles also say the fridge loses only one degree an hour when turned off. I've been travelling with it turned off for a couple of years and after a 300 mile trip the stuff in the freezer is still frozen and the stuff in the fridge is still cold, and that included opening it briefly for a drink or snack.
DrLewie is online now   Reply With Quote
Old 04-29-2016, 02:53 PM   #14
bikendan's Avatar
A-frames and popups don't have battery cutoff switches unless an owner installs one.
Equalizer WDH
Old 04-29-2016, 03:02 PM   #15
Be aware that if you live or camp above 5000' you probably can't run your fridge on propane (not enough air in the air :-)
ellen and ken, 3 dogs and Adventure Cat
2012 Mini Lite 2109S
2005 GMC Sierra 2500HD Duramax/Allison
ekrus is offline   Reply With Quote
Old 04-29-2016, 03:22 PM   #16
Never had problem with fridge on propane at higher elevations. Spent most of last summer in the 6500 - 9500 range
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-29-2016, 04:37 PM   #17
Just going by the manufacturer's instructions. We live above 5000' and generally go UP to camp. If our fridge runs at all on propane, it doesn't stay very cold. We get more consistent results with electricity (if we have no electric hookup, we use a big cooler with ice and/or cold packs).
Old 04-29-2016, 04:46 PM   #18
RSchleder's Avatar
Cool frig for 24 hours (if possible, if not as much as you can) and add food. Put frig control on AUTO and it will run on 120V when plugged in, 12V when attached to the tow vehicle & propane when not plugged in to 110V or 12V. It's amazing how smart your frig can be!!!!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 04-29-2016, 04:51 PM   #19
I realize that efficiency takes a hit, but this thread is about cooling while traveling, not boondocking. Took forever it seemed to boil spaghetti water at 8900 feet. We only use propane on the fridge going from full service campground to full service campground.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 04-29-2016, 04:59 PM   #20
Not quite. The unit runs on either 120v, or 12v AND propane. The unit will not run on 12v only or propane only.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
fridge, travel
