Old 12-29-2014, 12:29 PM   #1
T12RB
I have a 2013 Flagstaff T12RB; recently the grey plastic water filter cap broke at off at the top that connects to the water intake pipe. Does anyone know where I can get a replacement water filter housing connection?
ehazel is offline   Reply With Quote
Old 12-29-2014, 12:52 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Cheyenne Camping Center, 800-397-5673 / 563-284-6897 Largest Midwest FR dealer and will ship to you....
donanddona is offline   Reply With Quote
Old 01-08-2015, 09:12 PM   #3
If your filter system is made by Water-Pur I would trash it and use an outside filter. Search the forums for the topic "Water-Pur". This is a post of a terrible experience I had with my Water-Pur system. It will also provide a solution I took to remove the Water-Pur system from my A128TH.
dmtex
dmtex is offline   Reply With Quote
Old 01-08-2015, 10:12 PM   #4
Here is the solution to my Water-Pur system: I completely removed the filter fixture after disconnecting the inlet and outlet hoses. I joined the two hoses with a 1/2" x 6" SCH80 PVC nipple purchased from Ace Hardware, $1.49. No installation issues and no leakage. Be sure to wrap both ends of the nipple with plumbing tape.
dmtex
Old 01-09-2015, 09:33 AM   #5
dmtex
Either do that or put an accumulator in place of the filter. That can smooth out the water pump functioning and is a plug and play install.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 01-09-2015, 01:25 PM   #6
handbuilder's Avatar
I asked spouse to remove the water filter under the sink and gained better use of space inside the sink cabinet.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 01-15-2015, 12:12 PM   #7
Here is the solution to my Water-Pur system: I completely removed the filter ....
Same here.
After reading about low pressure, I never installed the filter in the housing. However that leaves water flowing through the housing to get mixed with quite a bit of air. So the housing was replaced.
If I feel the need for a filter, which I never have, I'll use an inline hose filter.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 01-15-2015, 02:54 PM   #8
Retread Popup Owner
Wojo's Avatar
Interesting. We've used our filter without any issue. I'll have to keep an eye on it, but until it gives me a problem I'll just keep on keeping on.
2014 Flagstaff T12DDST A Frame
2015 Nissan Xterra
2015 Nissan Frontier
Camping Photos
Camper Mods
Wojo is offline   Reply With Quote
