Old 05-27-2016, 08:58 AM   #1
"Tacky" lights on the camper
We camped in a pop up for 10-years and had some really fun "tacky" lights strung around the awning.
Now we have an a frame 192HW that doesn't have an awning. I'd love to put some on the outside of this camper as well.
But how???
Jodilc is offline   Reply With Quote
Old 05-27-2016, 09:04 AM   #2
Sc00ter's Avatar
We hang them off our awning, but you could clothes pin them to the rain gutter. For really tacky we back feed power through the seven pin connector and light up the clearance lights (in select crowds and friends if extra light is needed)
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 05-27-2016, 09:06 AM   #3
rsdata's Avatar
something like this will install on the new awning...
2014 Shamrock 183
Old 05-27-2016, 09:52 AM   #4
These work well too.
Camco 42693 Gray Party Light Holder
Iwritecode is online now   Reply With Quote
Old 05-27-2016, 11:17 AM   #5
MilCop4523's Avatar
use "tacky" 2 sided tape for your holders
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 05-27-2016, 11:22 AM   #6
pennypoppins's Avatar
Use some Command hooks, they can be removed when not being used. You could stick those things anywhere you have a solid surface!
Penny and Don Fuller
Greyhounds - Dubs
Bridge Angels Pi, Hannah, Mac and Essie
Shamrock 21SS
pennypoppins is offline   Reply With Quote
Old 05-27-2016, 11:37 AM   #7
jeff64's Avatar
rollumup-300
straps2tie straps
Rollumup Awning Party Light & Accessory Hold
Had these for years, attach your lights with the velcro strap. They slide into the awning track and rollup with the awning. Colors available. No grommets or clips
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 05-27-2016, 11:42 AM   #8
Rick_Geneseo's Avatar
Stick a 2 post signal flasher i. The trailer 7-pin. Your clearance and tail lights will flash.
Rick_Geneseo is offline   Reply With Quote
Old 05-27-2016, 12:59 PM   #9
D_B Travelers's Avatar
Correct me if I am wrong, but didn't Jodilc say they DIDN'T have an awning? Not sure the sliding tabs will be of much use with no awning, just saying...
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 05-27-2016, 01:03 PM   #10
MilCop4523's Avatar
a few 2 inch screws and a couple of these and your all set for the party.
wont affect the width of the trailer at toll booths and you won't walk into them after a few drinks.
Old 05-27-2016, 01:30 PM   #11
CaptnJohn's Avatar
Get 2 hooks used to hang plants on in the yard.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 05-27-2016, 02:58 PM   #12
I see this a lot, people answer with posts that do not pertain to original post. Why would they need awning holders when they have no awning.
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 05-27-2016, 03:18 PM   #13
KyDan's Avatar
String lights from tree to tree or tree to camper. You could even place 2 poles much like come with a badminton net and string lights between. String from roof rack to trailer.
Peace!
Dan & Rita D
Old 05-27-2016, 05:25 PM   #14
DanM-AZ's Avatar
I have two of these for hanging lights from to provide ambient lighting outside of the A-frame:
Amazon.com: Coleman Lantern Stand
I've also installed a water-tight 12VDC socket on the outside of the trailer to provide the 12V to the outside lights:
Amazon.com: Waterproof Accessory Lighter Socket
This photo shows the lantern hangers set up and my 12V power cord coming out of the side of the A-Frame:
The power socket is switched from the inside so turning the outside lights on or off is quick and easy. Four more of those 12V LED light bulbs are also hanging inside the canopy. Makes for a very friendly camp when the sun is down.
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 05-27-2016, 08:24 PM   #15
DanM-AZ's Avatar
And for those wondering, these are the lights:
Liroyal E27 4w 5v High-power Day White Light Bulb - - Amazon.com
The only problem is that they come on a slow boat from China. It could take a while before they get to you. I ordered two batches of four. The first batch came in about 3 weeks, but the second batch took 6 weeks. Two of the eight bulbs have died, but for the price, I'm ok with that.
I made a junction box that hangs in one corner of the screen room to connect the lights to. And you need RCA phono plug extension cables and splitters to distribute the power to all the bulbs. I'm an electronics engineer so I'm comfortable with fabricating the junction box and interconnecting cables where needed. You will have to figure out how to connect it all up based on your own level of expertise.
Dan
camper, light
