05-04-2016, 09:31 AM
Thinking of moving up
Hi everybody
I have a t19gbhw 2015 that I tow with a Toyota Tundra 5.7. I'm happy as a pig in I know what. Now my dw would like to have a toilet and shower in the camper. I won't set up anything in th aframe it's just too small. So the question is , what's a decent lite weight trailer with a separate toilet and separate shower that is aerodynamic and not so large that I feel like I'm towing a brick house behind me. The current setup and I barely knows it's there when towing. Right now I'm all in for 13k. I wouldn't want to spend more than 20k figuring I'm not going to get close to what I laid out already.
Any thoughts would be greatly appreciated.
2015 t19qbhw
2015 Toyota Tundra crewmax lmtd
2019 microlite 25bds
2015 tundra
05-04-2016, 10:06 AM
Generally speaking, if you don't want to be towing a brick house, but want a toilet and shower, you are probably going to end up with a single axle trailer with a "wet bath," i.e., the toilet is essentially in the shower. You can get this in a r-Pod and several other similar TT's like Scamp and Casita. These are all somewhat aerodynamic.
You can see the r-Pods here: r-pod Travel Trailers by Forest River RV
2011 Traverse LT, 3.6L, FWD
05-04-2016, 01:20 PM
x2!
Don't think that you'll find anything like what you want, that won't have a wet bath.
To have a separate toilet and shower, that you don't have to setup, requires more height and length.
05-04-2016, 01:33 PM
might be a little more than you are looking to tow but some of the small hybrids could work for you. I love my hybrid although i am getting tired of the set up, although fast and easy, and its a bit more to clean.
05-04-2016, 01:42 PM
I looked at RPod's before getting my A122SXR. I am 6'1" and could not stand up in the shower and the bed is short, only 75 inches as opposed to 80 inches.
You might check out the new Lance 1475 or maybe the 1575 but that might blow your budget.
Just my two cents...
2015 Rockwood A122SXR
2006 Toyota Tundra Double Cab 4x4
05-04-2016, 01:52 PM
The Lance looks nice will do more research. Thanks for the heads up.
05-04-2016, 01:59 PM
My brother has a 1685 and a good friend has 2285. They are both awesome and true 4 season. The 1475 and 1575 are not 4 season. My next camper will be a Lance, and probably a 1685. You can find a used 1575 for under 20k. Good luck!
05-04-2016, 02:21 PM
Why not get something like the Rockwood MiniLite 2304? NICE size bathroom and you can get the Murphy bed option that allows you to have a dinette AND a couch. I HATE sitting at a dinette, so the couch is a huge deal to me. Your Tundra won't break a sweat pulling it and you'll have plenty of room with a great bathroom. A good bit of storage for a camper it's size, too. Here's the floorplan if you want to check it out:
New Forest River Rockwood Mini Lite 2304 Travel Trailer RVs For Sale at The Original RV Wholesalers
05-04-2016, 02:57 PM
Thanks Dustman. That unit also looks quite interesting . Thank you
05-04-2016, 03:02 PM
You may also want to consider a TrailManor or if you are into used, you may be able to find a HiLO. I just saw a 2004 24 ft with a slideout.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi (with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
05-04-2016, 03:21 PM
We just got a 195BH. Yes, it's a square box trailer, but it has a tub/shower, toilet, as much sleeping space as the pop up but more "living" space, more counter space, non of the setup/tear-down work. It's easily towable by your truck, and we got ours new for under $11k incl taxes. We moved up from a pop-up, also.
weights just 3100 dry, 3900 gross.
some pics here:
http://www.forestriverforums.com/for...lbums2616.html
If you don't need the bunks, there is the 185RB that's even smaller/lighter.
Just an idea to consider...
-rvb
Ryan V. B.
2017 FR Wildwood XLite 195BH
2010 F-150 4x4, 4.6L
05-05-2016, 07:16 AM
Thinking of Moving Up
Here's another two cents. I can see wanting the toilet. That's one of the reasons we went from an A122S to the A213HW. But IMO showers are more of an inconvenience than anything else. The water gets out on the floor; the steam covers the mirror and walls; there's not much of a flow, and the water fills up your grey water tank quickly, -at least it does if your wife showers like mine. Most all the campgrounds we've been in have had decent showers. Obviously, they range in quality, but in general they're usable. Towing the A-frame has been a delight after years of heavy trailers and one 5th wheel. And I don't have to wait in line to dump tanks anymore!
Kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
05-05-2016, 08:20 AM
Kdot
Your right about the quality of showers and toilets they're fine for me. I figured if the toilet is there there should be a shower too. And ur right about pulling the aframe it is a dream. I'd like to stand pat, but u never know with the other half.
05-05-2016, 10:00 AM
We can provide all the advice we want, but we all know that in the end it is NOT going to be mudman's decision -
05-05-2016, 11:47 AM
I think you can find a lot of good trailers. I have a Tracer 240 AIR (Prime Time sister company of Forest River), weighs 4,000 lbs dry and I don't feel much with a Silverado 9,600 lbs towing capacity. They also have smaller units, check out 206 and I've been in the 215 Air, big back bathroom and shower. Good luck!
DP
2013 Tracer 240 AIR
2014 Silverado 1500
05-05-2016, 12:40 PM
Just remember we all (well almost all) started out in tents/dry camping on the ground then a shell then a truck with camper ect. So just except the fact one day you will get a bigger RV and a bigger TV. That's just the way it works.Njoy.
05-07-2016, 08:16 PM
Anyone know about the Sonic 170 made by Venture RV? Or how about Lance? Those are new names to us and just starting the research for an upgrade from our 192HW as we also want a toilet.
We love our 192HW
05-07-2016, 08:35 PM
A lot depends on what that 192HW is pushing.
05-07-2016, 09:02 PM
We had a Chalet brand Aframe for a handful of years after a tent trailer for even longer and we thought for a long time that we had all we were ever going to want.
After a few longer trips each season and having some horrible weather we found the floor space just not adequate enough. It would have been nice to have some space to stretch our legs, or make it easier to walk around one another. We are almost always dry camping and still wanted something to boondock with but gave us a little more space. originally we wanted the rockwood 1809S but ended up with the 2109S due to the furnace placement and bed layout. This new tt maybe a bit over kill but we love it. It isn't going to travel to some of our previous boondocking locations that our trailboss equipped chalet got into but we can see ourselves in it for the next 10 years.
Those tt's maybe a bit more than what you are looking for but I do not believe you need to get into a 25' trailer either. Best thing is get out and walk around some rv lots and get a feel for what works for you. If they have slides make sure they are extended, play with the features, turn the appliances like the furnace on. If they do not have power hooked up get them to grab a power box.
Weight wise, well our fuel economy will take a hit on longer trips but we know when we get to our destination we are going to be happy!
05-07-2016, 09:29 PM
friend. but we can see ourselves in it for the next 10 years. Ya right
Go out and njoy camping. Remember ya can't take it with you.
