Old 04-30-2012, 09:24 PM   #11
Mostly Harmless
thehamguy1's Avatar
After a little more than a year of owning it and over 7000 miles pulling it, we've had no serious problems with our A128. If there was something I wasn't completely happy with about it, it was easy enough to make modifications. If your family will fit in one and your vehicle will pull it you'll probably enjoy it.
Next stop: Alaska!
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 05-03-2012, 08:40 PM   #12
Hey Hamguy...can you give me any input re putting up sidewalls in windy conditions?
2lvrvn is offline   Reply With Quote
Old 05-03-2012, 09:26 PM   #13
Mostly Harmless
thehamguy1's Avatar
We've been camping in some really windy conditions but we were already set up when the winds came. I think the basic advice would be the same for setting up as taking down: orient the trailer so it's pointing into the wind if possible. The front roof section hooks over the rear one, so wind blowing against the front roof will help keep the roof locked together until you can get the first sidewall up and latched. Waiting until the wind dies down at twilight is another strategy, as long as the wind actually does die down. My third suggestion is to find a sheltered spot in the campground, put up the walls there, then pull the camper back to your campsite. It's no taller than a travel trailer so there shouldn't be a problem taking it on CG roads.
I've read of people passing a rope over the roof section before lifting it and assigning someone(s) to keep light tension on it while the roof goes up. Not sure that would work; what keeps the rope in place during this time?
Others will chime in with better answers I hope. Lots of clever folks on these forums. Which Hardside do you have?
2011 Rockwood A128
60W solar system
Old 05-04-2012, 08:23 PM   #14
I am looking to purchase the 128S. You have so much great input. Thanx for sharing yr knowledge. This IS a great forum, can't wait to become a member with some good ideas to share.
Old 05-04-2012, 08:40 PM   #15
We recently purchased an A122, we have downsized from a 29' 5th wheel. We wanted a bed with a mattress, and it sleeps really well compared to the campers that you have to sleep on the cushions. Yes it is small, but we have everything that is necessary. We have lost our bathroom, along with a lot of the upkeep that goes along with it. A porta-potty serves us well, and is easier to empty than the black water tanks. The only bad thing we have heard about these campers is the tires may fail. We are very happy with our little camper.
Laura June is offline   Reply With Quote
Old 05-04-2012, 10:04 PM   #16
Rockwood Premier A126
gregory's Avatar
Keep the tires properly inflated and, under normal conditions, the tires should hold up fine.
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 05-05-2012, 08:43 PM   #17
We have a A126 and for a couple its very good easy to set up
lenwick is offline   Reply With Quote
Old 05-05-2012, 09:02 PM   #18
chucker25's Avatar
We have the 2013 A128S and the new front locker is great and adds a LOT of storage, which these units tend to lack.
We were originally considering the A122 (fixed bed) but after a lot of research at the dealers decided on the A128S. It gives you to option of an extra table, can leave down as bed if desired and just seemed to have the most floor space and "openness" (if you can imagine openness in these rigs ). The trailer is bigger and heavier than you might think and the tongue weight on ours with the storage unit is around 300lbs empty (I think the locker moves a fair amount of weight forward, and will so when the locker is packed. So you do need to consider your TV.
As for space 98% of the time we camp just the 2 of us, and we don't mind being 'close'
Good luck.
2013 Rockwood A128S
Ford Ranger
chucker25 is offline   Reply With Quote
Old 05-16-2012, 01:49 AM   #19
MrMeyer's Avatar
Happy with our A122BH so far.
Just got back from New Mexico and Arizona and logged a little over 4000 miles, stayed in it where we had to use the furnace in the mountains and the AC in the desert and couldn't be happier. Stayed in it 9 nights with my wife and cattle dog and a pile of gear, plenty of room. We love the deck on the front where we put a large Contico storage box that contained all our cooking and camping gear and had 2 more boxes in the back of my truck to carry 2 Honda parallel generators, wood and some food. This trailer is a breeze to put up and take down, amazing some other campers who watched in amazement at the speed with which we did it. Just make sure you are fairly level when putting it up. If you are going to use the furnace I would advise you to fire it up and let it cycle for several hours to burn the oil off the heat exchanger since the smell was kind of annoying. The AC worked great, temperature was 99 in the desert and it cycled on and off keeping us a cool 72 where we had it set with plenty of capacity to spare. We have had no warranty issues yet and plan on pulling it back out to AZ in September for 2 weeks and use it this as many weekends as we can here in the Midwest this summer. Good luck on your decision, hope this helped.
MrMeyer is offline   Reply With Quote
Old 05-16-2012, 09:25 AM   #20
Mostly Harmless
thehamguy1's Avatar
Welcome to the forum, MrMeyer. Happy to have another happy A-frame owner join us! Be sure to post pics, it's how we all get by between our own trips.
2011 Rockwood A128
60W solar system
