Old 07-09-2013, 06:51 AM   #11
acadianbob's Avatar
Originally Posted by Jeep4Two View Post
The biggest enemy to trailer tires is low air pressure. Low pressure equals heat buildup equals blowout.
Yep!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-09-2013, 06:57 AM   #12
Originally Posted by Mister View Post
Your probably running on class C's
Forest River puts "D" weight rated radials on A frame trailers. They use the higher rated tires because of the fairly large CCC compared to most small campers. More than 50% of the factory "dry" weight, or 1/3 of the GVWR in some cases.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-09-2013, 08:00 AM   #13
max tire pressure for our trailers is 65lbs .. as stated on the sidewall. i however fill them to 55lbs max ... works for me, and i have been all over the place in eastern Canada and the southeastern parts of the USA .. without incident.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 07-09-2013, 08:46 AM   #14
Mostly Harmless
thehamguy1's Avatar
It seems to me there are two issues: what pressure to use, and are these the right tires? Folks have answered the pressure question--obey what it says on the tire, not on the camper. But as Tom pointed out, these are not the right tires for our Aframes. Even my older and lighter A128 (without a front storage bin or toy hauler platform) requires Load Range D tires. I keep them at 65# and they still look good at over 18,000 miles.
Check all three tires to see if they're all the lighter-duty Load Range C tires. I think the load range is molded on the tire as is the max pressure. There may have been a mixup on just one tire. I was told by a factory rep that Aframes are built on the same line as tent campers, so maybe you got a tire or tires for some other unit. However it happened, this is a warranty issue in my book. And the basis for a lawsuit if anything bad happens due to incorrect tires. If the dealer tries to stonewall you, contact the factory.
I'd suggest not driving Interstate speeds with these lighter tires, and not carrying much more in it than it came with, until the right "shoes" are on your baby.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 07-09-2013, 10:42 AM   #15
I don't think we have established the actual tires on the camper yet, just that he read 50 pounds of pressure in them. Its seems more likely to me that a inattentive person at the dealer under-inflated them than FR put the wrong tires on.
Jsusluvsyou, you are on the right track in personally establishing the exact tires on your trailer. There is no other way to answer the question. The FR dealer cannot do this over the phone nor can we, on this forum, without seeing the labeling.
If you cannot do it yourself, take the camper to a local tire dealer or trailer shop and ask them to explain the tire labeling to you. Any reasonable shop will be glad to help and since you will need to meet them at some point, just do it now.
Tom
2012 Rockwood A122S
Old 07-09-2013, 12:06 PM   #16
Mostly Harmless
thehamguy1's Avatar
Must have misread the OP, thought he said the 50 pounds was what he read as the max pressure on the tire itself.
2011 Rockwood A128
60W solar system
Old 07-09-2013, 04:00 PM   #17
65 is a solid number / for the sidewall numbers ... remember our Aframe units are a modification of the Premiere series pupups of the late 2011 plus. Basically both trailer boxes are made the same day in the factory, including suspension/tires and other road stuff and exluding the assisted roof raising system ..
d-mo
2011 Rockwood A122
Old 07-09-2013, 06:19 PM   #18
Mister's Avatar
Interesting... This I did not know... But I applaud FR do doing it. Almost all TT out there are running on the very limit of their tires. Nice to know someone's thinking ahead.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
Old 07-09-2013, 10:18 PM   #19
Jsusluvsyou's Avatar
Thanks for all the info. I checked the side of the tire (sure is fine print) looks like it said max cold was 65. I called lazy Days mechanic and he states they should be at 65, he suggested I check my gauge which I will as I used a new one.
Jsusluvsyou is offline   Reply With Quote
Old 07-10-2013, 10:08 AM   #20
This should help anyone needing to know more about their ST tires.
Tom
2012 Rockwood A122S
