Old 10-13-2015, 12:06 PM   #11
wmtire's Avatar
Originally Posted by SpringerPop View Post
The date code is required by law to be mounted to the outside so it is visible.
Uhh, there may be a little confusion here.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-13-2015, 12:27 PM   #12
wmtire's Avatar
Had to find my link to the regulations:
The full DOT code (with date) only has to be on one side. This side is supposed to be the "intended" outboard sidewall, but by no means is an absolute. There is no law that states the tire has to be mounted with the "intended" outboard sidewall for sure facing outwards.
Here is the link to the long regs, that is interesting reading for some people. it explains they way tire molds are made and why the full DOT code with date is not practical to be put on both sidewalls. It also give a lot of the history that went into the decision making for the way things are the way they are now:
Here is the link:
Tire Safety Information, Final Rule.
and here is an excerpt:
VII. Agency Decision regarding Final Rule
  • A. Summary of Final Rule and Rationale
The final rule establishes a single standard for light vehicle tires, FMVSS No. 139, New PneumaticRadial Tires for Light Vehicles.�The final rule contains labeling requirements that address the following aspects of tire and vehicle labeling: tire markings, the Tire Identification Number (TIN), vehicle placard content and format, placard location, and owner�s manual information.�NHTSA will also be establishing upgraded safety performance requirements for tires in a forthcoming final rule, which would also be included in the new standard.
The rule applies to all new and retreaded tires for passenger cars, multipurpose passenger vehicles, trucks, buses and trailers with a gross vehicle weight rating (GVWR) of 4,536 kg (10,000 pounds) or less, manufactured after 1975, and to all passenger cars, multipurpose passenger vehicles, trucks, buses and trailers with a gross vehicle weight rating (GVWR) of 4,536 kg (10,000 pounds) or less. [4]� The requirements are summarized below.
NHTSA has decided that the size designation, maximum permissible inflation pressure, and maximum load rating must be placed on both sides of light vehicle tires.�The full TIN will be required on the "intended outboard side" of the tire and either the full TIN or a partial TIN, containing all aspects of the TIN except for the date code, will be required on the opposite side." "Intended outboard sidewall" is defined in FMVSS No. 139 as the sidewall that contains a whitewall, bears white lettering, or bears manufacturer or model name molding that is higher or deeper than that on the other sidewall of the tire.�If a tire does not have an intended outboard sidewall, the tire must be labeled with the full TIN on one sidewall and with either the full TIN or a partial TIN on the other sidewall.�Requiring that a form of the TIN, whether the full or partial TIN, be on both sides will ensure that important consumer information will be on the outward facing sidewall, regardless of how the tire is mounted.�Requiring that the other items of information be on both sidewalls will aid consumers in properly maintaining their tires and loading their vehicles.
NHTSA is making another change to the TIN.�The rule requires that each character in the TIN be 6 mm (1/4") high.�The agency believes that a requirement for a uniform TIN font size will significantly improve the readability of the TIN.
Old 10-13-2015, 12:52 PM   #13
Yeah, I spent a few years in the tire business.
Was a service manager for Firestone tire and rubber. Also worked at Discount Tire. Never heard that the date codes had to face out.
90% of the time they are inboard.
I could see a tire being mounted backwards if it were a uni directional tire, but I have never seen one of those on a trailer, only on performance cars.
2007 Work & Play 34RL Toyhauler.
2003 GMC Sierra HD Dmax Alli.
036.6turbo is offline   Reply With Quote
Old 10-13-2015, 01:22 PM   #14
schrederman's Avatar
I've been a DT customer for years and have never received anything but excellent service from them.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 10-13-2015, 01:37 PM   #15
Left Coast
Unless there is a date code on both sides, the shop can't legally mount it "backwards".
Since we're on the subject of sidewall markings, a quiz:
What do the colored circles on the sidewalls mean?
Does your tire shop pay any attention to them?
Pop
On Goodyear slicks the (dot) goes to the right if your behind the car.
Old 10-13-2015, 07:40 PM   #16
The Weatherford DT store is a great place to do business. The manager is very honest and a really nice guy.
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 20 days (so far)
elchilero53 is offline   Reply With Quote
Old 10-13-2015, 08:33 PM   #17
After having a blow out on a Load Star tire with less than 8000 miles on it I went to Discount Tire and ask for 4 new American made tires to which they said no problem. We'll get Goodyear Marathons made in the good ole USA. 2 months later while winterizing I notice the Goodyears were made in China! Boy was I POd. I sent an email to the store that I got the tires from and to corporate DT. Within an hour I had emails back from both of them apologizing and asking what they could do to make it right. I said I wanted Michelin tires but I couldn't get it in until spring. They said no problem. The next April they put on the tires I ask for and only charged me the difference. Of course they pointed out that the set of Michelins I got were made in the UK.
All in all I'm happy with Discount Tire.
bop11 is offline   Reply With Quote
Old 10-13-2015, 08:34 PM   #18
RetiredRVer
Springerpop; I believe the colored dot is to be lined up with the tire valve in order to achieve better tire balancing.
checkmate99 is offline   Reply With Quote
Old 10-13-2015, 09:12 PM   #19
wmtire's Avatar
Originally Posted by bob caldwell View Post
Wasn/t there a tread a while back about tires with a 'v' design tread?
They weren't actually V-tread and are not directional tires:
Vail Sport Radial Tire
Old 10-13-2015, 09:36 PM   #20
Left Coast
OK....Is post about 'dot' correct? post 18
tire, tires
