Old 01-22-2015, 07:53 PM   #1
Tires
I was wondering how often do you change your A frame trailer tires? Where to purchase your tires? Thanks for your responses in advance
JoArt is offline   Reply With Quote
Old 01-22-2015, 08:16 PM   #2
RedLdr1's Avatar
There are a lot of tire threads scattered on the forums here. Do a search on "China bombs" or "ST tires" for threads on tires. The general consensus I'm reading is that ST tires get replaced every 4-5 years regardless of mileage. The exceptions are if you are very high mileage user, and actually wear the tread down, or if they begin to show deep cracks in the rubber.
Based on what I have read here, and on other forums, the best ST tires are Maxxis, Kumho 857, and Goodyear Marathons. Check their websites for your local dealer and tire fitment information.
Which brand tire to use questions will generate a lot of responses both for and against any of the brands I mentioned. I've been reading about tires since before we purchased our trailer and the topic does generate strong opinions...
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is online now   Reply With Quote
Old 01-24-2015, 10:48 PM   #3
Where would you find these type of tires? Do most tire dealerships work on trailers or is that a specialty?
Old 01-24-2015, 10:59 PM   #4
Just got mine off Ebay. Free shipping and no tax was cheaper than anywhere else I could find...
firedaniel is offline   Reply With Quote
Old 01-24-2015, 11:49 PM   #5
Fulltime family RVer
I ordered from www.discounttiredirect.com and took the wheels and tires to the local tire shop. For a $20 tip directly to the techs, they switched them over for me.
Old 01-25-2015, 12:18 AM   #6
GreenImp's Avatar
Send a message via MSN to GreenImp
The link above redirects to the main Discount Tire/Americas Tire site....They intentionally make it difficult to access the cheaper site.
http://www.discounttiredirect.com/direct/home.do
Edit...Actually...I just found that it's not the link thats the problem...it seems to be cookies from the main site. If you have trouble accessing the Direct site, clear out your cookies or try a different browser.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 01-25-2015, 09:41 PM   #7
I have had good deals from
etrailer.com for good tires and free fast shippinng.
mickrock is offline   Reply With Quote
Old 01-27-2015, 09:09 PM   #8
The Aframe dealerships I've talked to do not change tires. They only sell the the OEM tires already mounted on wheels.
One word of caution, FR Aframes have D load range rated tires while most campers use C range. Make sure the tire dealer orders D load radials and double check them before the installation.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 01-27-2015, 09:24 PM   #9
gashog's Avatar
Originally Posted by Pooneil View Post
The a Aframe dealerships I've talked to do not change tires. They only sell the the OEM tires already mounted on wheels.
OK this is a stupid question, whats a Aframe? I'm assuming they are a bumper pull? my 2015 Rockwood Windjammer 3029W came with "C" rated china bombs. I asked Forest River when I replace my tires if I could go with "D" rated. here's what they said:
We don't recommend changing your tires to D rated tires. We install C rated tires and we don't recommend changing away from a C tire. If you want specs on what the rims then I would have to put you in contact with Lionshead our supplier for the tires and rims. You can contact them at 574-533-6169.
Warranty Administrator
Rockwood & Flagstaff
Forest River Inc.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 01-28-2015, 12:03 PM   #10
RedLdr1's Avatar
I'm not sure about D Load Range being OEM for 2015. My T21QBHW came with ST205/75-14 C Load Range tires and it is the biggest, heaviest A-Frame FR currently makes at 2,352 pounds Unloaded Vehicle Weight and a GVWR of 3,336 pounds.
That hefty weight doesn't leave a lot of room for error on most C Load Range tires if you are at, or even near, the trailers maximum GVWR. For that reason, along with a general concern over the stock tires, I'm looking at replacing the OEM tires.
My Solution:
I've decided to go with Maxxis 8008 ST215/75-14 C Load Range tires. While staying with the OEM 14 inch rim by "upgrading" to the 215 width, versus the OEM tire's 205 width, provides a slight increase in tire load capacity. The 215's have a maximum load of 1,870 pounds per tire, 3,740 pounds per set, versus the Maxxis ST205/75-14 Load Range C tires at 1,760 pounds per tire or 3,520 pounds per set. Both tires have the same maximum Air Pressure, 50 PSI, and are close enough in size that I do not expect to have any wheel or fitment concerns.
While that change is only 110 pounds per tire, 220 pounds per set, the higher rating adds a little bit more comfort margin for me at roughly the same price. When looking at only the trailers GVWR (3,336 pounds) the 215's are rated at approximately 9% higher than the GVWR, at the maximum allowed weight per set, versus approximately 5% higher than the GVWR for the 205's. There is my "comfort" factor...
I do not advocate going over the factory GVWR, running "overweight", nor do I intend to ever do so. And I know that upgrading tires alone will not increase my GVWR rating by even one pound. But I believe upgrading to the Maxxis 215's will result in a less stressed, cooler running tire which is one of the key factors in tire life. I'll also be installing a Dill TPMS at the same time I swap tires.
I advise anyone looking at replacing their tires to do their own research and carefully check out their options. What I, or anyone else, thinks will works best is not necessarily the best option for everyone. I do not claim to be a ST tire expert, nor have I found one I believe yet , so I've spent quite a bit of time researching before I made my choice. This "upgrade" is about $600 for three tires, I'm replacing the spare tire as well, and the Dill TPMS. I'll find out if it was a good choice and will only have myself to blame if it wasn't...
I'll get off my soap box now.... and I apologize in advance if this came across as a "rant" as it wasn't meant to be one....
Wayne and Christine
tire, tires
« Cook top | Beeping? »
