Old 04-22-2016, 07:17 PM   #1
Top of propane tank cover is cracking up!
The white cover around my propane tanks is cracking up on the top.
The rest of it is still in good shape.
Is there any repair to fix the top, or do I end up buying a new one complete?
mickrock is offline   Reply With Quote
Old 04-22-2016, 07:52 PM   #2
crunchman12001's Avatar
Why bother fixing it if it is broken $22.55 for a double 20lb cover. Sometimes you got splurge a little.
Amazon.com: Camco 40523 Heavy-Duty 20lb Propane Tank Cover (Polar White): Automotive
2017 Salem Villa Estate 395RET- Ordered - Coming soon
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 04-23-2016, 07:03 AM   #3
What crunchman12001 said.
Treat the propane cover as a wear item and replace it. It can be subject to a great deal of wind pressure and you don't want it disintegrating while on the road.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-23-2016, 07:09 AM   #4
Yes "Slip on's" are cheap, I always liked the Early ROO covers that were Formed to the Tongue and front of the trailer! Youroo!!
Old 04-23-2016, 07:29 AM   #5
Ford Idaho's Avatar
I would drill a hole on each end of the crack to keep it from getting bigger.
Then grind a channel along the crack, fill it in with JB weld and let cure.
Sand it down smooth and paint.
Ford Idaho is online now   Reply With Quote
Old 04-23-2016, 12:44 PM   #6
I bought one of those white plastic covers when our fabric cover started falling apart. It was $10 more than a replacement fabric cover. The fabric covers crack and rot pretty fast in Colorado UV.
Can't say I'm a lot happier - I had to bungee the plastic cover underneath to make sure it would stay on. The plastic just doesn't fit very tightly around the tanks.
I will admit the top access to the valves and switch-over regulator is much, much easier than lifting off the fabric cover.
Fred W
2014 Rockwood A122 A-frame
Old 04-24-2016, 07:02 PM   #7
My trick for this was to use steel fishing leader wire with aluminum carabiners on each end.
Tom
2012 Rockwood A122S
Old 05-09-2016, 01:14 PM   #8
I was just about ready to buy a new cover,
when I thought about a tube of white bathroom caulk that I had only used a small portion of at an earlier time.
I took the cover off of the tanks and cleaned the top surface with some glass cleaner.
After laying the cover flat, I applied the rest of the tube of white caulk to the top surface area of the tank cover. I used a small piece of cardboard to spread it around some. Then I put the cover back over the propane tanks, and continued to spread the caulk into the cracks of the vinyl and around the entire surface of the top.
I actually felt like a modern artist, and the appearance has somewhat of a sculpted effect. Sorry, I won't post a pic, but the cover is saved.
I am guessing the cover will be good for another couple of years, with some vinyl protectant sprayed into the rest of it.
Thanks for the suggestions.
$5 for a tube of caulk versus $25 for a new cover...
Old 05-09-2016, 04:17 PM   #9
I thought you had one of the really expensive $22.00 ones, here is a vinyl one for $11.45.
Robot Check
I am almost speechless over your frugalness.
2015 F-250 FX4
Old 05-09-2016, 04:29 PM   #10
(Dry Huunday)
DreiHunde's Avatar
Heck yea! Money saved on that is money played somewhere else!
And if you had already purchased the caulk for another job then this repair cost nothing!!!
Improvise adapt overcome!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
cover, propane, tank
