Old 07-09-2016, 08:24 AM   #1
Chucka
Torsion bar
I have one broken torsion bar (for lifting the roof) on my 2012 Rockwood A128S A-frame. What's involved to replace it and what might it cost to have a dealer do this?
jrkrueger is offline   Reply With Quote
Old 07-09-2016, 06:34 PM   #2
The dealer would certainly be the place to buy the spring. If you bought the extended warranty, it may be covered. Otherwise it may take some work.
I can only speculate but it would seem that the roof haves would have to be separated and the affected side raised until it take the tension off the spring. If that is what is required. I'd be sure to do it inside with some help. Depending on the cost, you might want to do both springs on the side at the same time.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-10-2016, 04:42 PM   #3
It looks like a pretty easy fix. On the Aliner owners site there is a step by step with pictures on how to replace the roof springs. The web site is Aliner Owners Club, look in the DIY section.
sundancer330 is offline   Reply With Quote
Old 07-10-2016, 06:01 PM   #4
That is a well written report.
Replacing Roof Springs and Bungees | Aliner Owners Club
Tom
2012 Rockwood A122S
Old 07-10-2016, 10:26 PM   #5
Process would be similar to Aliner but keep in mind F.R. uses torsion bars and not springs as aliner does. Bungees are about the same.
2012 Rockwood a124
mzak is offline   Reply With Quote
