Old 03-31-2016, 02:14 PM   #1
The Wayfarers
Palletbob's Avatar
Torsion bar axle for Aframe 128S
I have had two set of tires on my Aframe I bought last year. It was only two yrs old and needed new tires which caused concern then. After a year I need new tires again because they are both worn on the inside. i have measured and the front and back of the tires are a 1/2 inch wider in the front. I assume the suspension need adjustment and I need a new axel as there is no adjustment to be made. Does anyone know the River Forest Number to call so I could order a new axel. I live in the Phoenix area
2013 Chevy 1500 Silveradro
Days camped 2015:98 Az, Chi,Mn,N.D.,Mt,Id! Wa, Or,Ca
2016 camped 118 Az,Chi,In,Mi,Oh,Ny,Vt,NH,M
2017 camped 88 az,Chi,Mo,Ok,Nm,Co,
Palletbob is offline   Reply With Quote
Old 03-31-2016, 03:40 PM   #2
My first question would be how much weight are you putting in the trailer my second question would be what pressure do you have on the tires
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 03-31-2016, 04:04 PM   #3
The Wayfarers
Palletbob's Avatar
We haven't stored much in the trailer as last yr we towed with a van. We kept the tires inflated to 55lbs as recommended by new dealer we bought recent tires from. But as tated earlier we have a half inch difference between the front of the tire on both sides and the rear of the tire. 75 inches on front and 74 1/2 in the back.
Old 03-31-2016, 04:32 PM   #4
Head Rambler
Since you're out of warranty, I wouldn't call Forest River about the axle. I'd take it to a place that repairs Ag, boat or utility trailers and ask them for a replacement axle. It most likely has a 3000lb axle. If you want to replace it yourself just get the numbers off the axle and order one online.
Gotta go campin!
Old 04-01-2016, 07:03 PM   #5
Too old to be too smart
SpringerPop's Avatar
I just delivered my torsion-axle'd trailer to an alignment shop that specializes in this kind of work.
It's not cheap, but there are places that do that kind of work.
I imagine it involves chains and hydraulic rams, but I didn't ask.
Phoenix is a big town, and somebody MUST do it near there.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 04-01-2016, 07:58 PM   #6
Id seriously now be concerned how all the twisting and torque would do to both the frame...and walls of your unit . ..as these aframes are built pretty tightly.
2011 Rockwood A122
Old 04-01-2016, 10:26 PM   #7
I have a 5th wheel with torsion bar axles and when a tire wore the outside tread bare in 200 miles we found the weld holding the axle on was busted. Looked at all 4 and found all 4 had the outside weld broken (also welds inside). Had them re-welded and then got to a frame and axle shop where they were able to do an alignment. Perfect wear now at 4,000 miles.
bplantcjf is offline   Reply With Quote
Old 04-03-2016, 10:34 PM   #8
A bent axle from overweighting an a-frame would be pretty unusual considering how much cargo capacity there is and how little room there is to put stuff. I'd have it inspected by the dealer or an independent trailer service center to figure out the problem. Afterall the axle is not an RV specific part. If the axle is bent, it may not be too much more to buy a new one than to do a repair, considering labor.
The assets of AL-Ko Axis, that division of Al-Ko that manufactures these axles has been purchased by Dexter. Often when these purchases are for "the assets of" is means there was some substantial problem with the original company. So keep that in mind when consulting the service center.
The AL-Ko Axis Corporate office number if you want to talk to them is 574 - 294 - 6651.
AL-KO
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
frame, a-frame
