Old 04-02-2013, 07:35 AM   #11
Originally Posted by ko777 View Post
How much did the air bags cost? Did you measure how much sag you had before and after the air bags?
I have the 2007 Torrent SUV which has the same towing capacity as your SUV and a A128S. I got .25 inch rise in front and an 1 inch sag in the rear, it was measured from the center of the tire well to the ground. The propane tanks where off and the tongue weight was 340 pounds. The trailer was not level hitched, I have to replace my ball mounts to raise it by 2 inches. I'm interested with your stats for comparison.
Does anybody know by how much you could be off +/- inches the level of a hitched trailer? I think if it is too low, it my pop out the ball on sudden hard stop or bump, it happened once on me but it maybe mounted wrong, I now double check the mounts.
Air bags were like $80 and the compressor unit around $220. Before I inflate the airbags I probably get around 2" of sag in the rear. After I inflate them it almost goes back up to stock. Front end lifts around .4 inch and I am sitting right around 330-340 with everything loaded (propane tanks still on the front).
I think the biggest advantage to the air bags is not only levelling it back out, but at the same time the ride is so much better and it will save my suspension in the long run while towing.
rkuffler is offline   Reply With Quote
Old 04-02-2013, 04:11 PM   #12
OutAndAbout's Avatar
Thanks rkuffler, just the kind of infor im looking for. camping already up north are ya. I use to like cold weather camping, the older you get the less you like it.
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
Old 04-02-2013, 04:15 PM   #13
Thanks gregory, hadn't thought to check what edmunds had to say. a lot of good info there.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 04-02-2013, 04:19 PM   #14
Thanks D-mo, the chip is a good idea and I havn't ruled out Nissan yet.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 04-02-2013, 07:40 PM   #15
pm me if you decide on the nissan .. as i have a few value notes also about superchips tune ...
enjoy the purchase ...
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 04-04-2013, 12:30 PM   #16
IndyRC's Avatar
I tow our A127TH with the current gen Taco and it does great. I have the Access Cab, V6 TRD 4X4 with 6sp manual. When I got it I didn't want the Double Cab, but now that I'm towing a camper, I kinda wish I had the double just for more people. Otherwise I'm not left wanting a bigger truck. I'm toying with the idea of getting a full size truck, but it has nothing to do with towing the A-frame. BTW I've gotten around 14mpg one the few trips we've been on with the camper.
IndyRC is offline   Reply With Quote
Old 04-04-2013, 01:56 PM   #17
IndyRC, thanks for the info. 14 mpg is better than what I get with my F150 pulling a pop-up, about 11 mpg.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 04-04-2013, 04:06 PM   #18
Rockwood Premier A126
gregory's Avatar
Wow, that is pretty bad! I see now why you are having an issue with your F150. Is your truck a 4x4?
Reason I'm so taken back is that we get 16-18 mpg towing our A126 with our E150 (4.6L) cargo van and 18-20 not towing.
I guess popups are heavier too...?
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 04-04-2013, 04:27 PM   #19
gregory, yes its 4x4, 5.4 triton with a 4:11 posi-track rear end. at best, not towing I get around 15mpg.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 04-04-2013, 09:11 PM   #20
gregory's Avatar
Ouch! I figured something like that had to be going on. I understand that it would get in your pocket driving it daily.
Our E150 has 3.73 limited slip differential. It's smaller motor and no 4x4 makes it lighter weight and helps with mpgs. Still, I feel your pain at the pump.
Gary installed a ScanGauge II on the van in 2008, so we see real time and average mpgs. Even though we are conservative drivers, one tends to modify their style of driving with that info in your face.
Best of luck with your tow vehicle decision.
Deb
Deb & Gary
