Old 04-01-2013, 10:15 AM   #1
OutAndAbout's Avatar
Towing with small size pickup.
Hi all, Iím getting ready to change things up in tow vehicle and camper. Looking at the Toyota Tacoma and the Rockwood A122S or Flagstaff equal. I know that going from a Ford 150 to the Tacoma is going to make a difference in towing power and the weights between the A122S and what I have are close. My question is if you tow youír a-frame with a Tacoma or any small truck do you wish you had a full size truck and for what reason?
Thanks.
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
Old 04-01-2013, 11:58 AM   #2
We had a Chevy Colorado. We thought about using it to tow but, as a tow vehicle there far more "PROS" then "CONS" for upgrading. We upgraded to a GMC 4x4 1500 Sierra. We wanted more room, wanted a better towing capibility, wanted the 4x4 option because we never know where the roads will take us. The mileage wasn't even worth complaining. The smaller engine will work harder thus use more gas. The only advantage we saw for staying with the smaller PU was that after we unhooked the camper, the gas mileage was better for cruising around. Our two sense......LOL
Lynn & John
Point Pleasant, NJ
2011 GMC Sierra ExtCab 4x4 Pickup
2012 Rockwood A126
jmfpanzerman is offline   Reply With Quote
Old 04-01-2013, 12:14 PM   #3
daydreaming about camping
jeeplj8's Avatar
what are the weights on the a-frame you are looking at?
I just saw one in the campground the other, towed by a Kia mini-van.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 04-01-2013, 12:28 PM   #4
Our A-126 has the max weight of I believe it to be 3600lbs. Empty I'm thinking about 2200lbs. That may not be accurate but not too far off I imagine.
Lynn & John
Point Pleasant, NJ
2012 Rockwood A126
Old 04-01-2013, 12:42 PM   #5
jeeplj8's Avatar
What are ratings on the Tacoma? If you are looking new, I believe they are actually rated fairly high, well above those weights anyway. It may not have CCC to give, but the tongue weight should still be very manageable.
Old 04-01-2013, 01:46 PM   #6
A122S weighs about 1,195 lbs, Tacoma can pull about 6,200. There is no problem there, just thinking about other reasons.
jmfpanzweman, the A126 a-frame should weigh around 2,000 lbs +/- about 100 lbs. unloaded. My pickup is my only transportation. Better gas millage when not towing is one reason I'm thinking about going smaller. I do like the size of my F150, makes it easier to hall canoe and kayaks'.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 04-01-2013, 03:35 PM   #7
I am towing our A122S with a 2013 Santa Fe 2.0T Limited. I did add air bags to combat the rear end sag and they worked awesome. Well until the air line sat on the exhaust and sprung a leak (fixed now).
Anyways we went camping this last weekend so we had it full of food, beer, lawn chairs, accessories, and some additional appliances. Went up some steeper hills (we went to the mountains) and the RPMs never hit above 2500 RPM all while keeping it at around 100KM/H (63mph or so). I mean you know its there but it towed amazingly well and I never had an issue keeping the speed up.
Gas mileage went from around 27mpg normally on highway to around 20-21mpg while towing.
rkuffler is offline   Reply With Quote
Old 04-01-2013, 04:18 PM   #8
ko777's Avatar
How much did the air bags cost? Did you measure how much sag you had before and after the air bags?
I have the 2007 Torrent SUV which has the same towing capacity as your SUV and a A128S. I got .25 inch rise in front and an 1 inch sag in the rear, it was measured from the center of the tire well to the ground. The propane tanks where off and the tongue weight was 340 pounds. The trailer was not level hitched, I have to replace my ball mounts to raise it by 2 inches. I'm interested with your stats for comparison.
Does anybody know by how much you could be off +/- inches the level of a hitched trailer? I think if it is too low, it my pop out the ball on sudden hard stop or bump, it happened once on me but it maybe mounted wrong, I now double check the mounts.
ko777 is offline   Reply With Quote
Old 04-01-2013, 05:16 PM   #9
Rockwood Premier A126
gregory's Avatar
Edmunds review seems to favor the V6 Tacoma for "frequent hauling and towing". You may fall into the category more of an occasional hauler/tower...
For more details, in the link below you can pick a specific year by clicking on the blue "year" box.
This will give you more info on the different models (within the Tacoma line up) for varying mpg etc.
Here's a link that might be helpful:
Toyota Tacoma Review - Research New & Used Toyota Tacoma Models | Edmunds
hth,
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 04-02-2013, 07:26 AM   #10
I tow with a Nissan Frontier 4x4 Crew. The truck pulls very well, and has no issues at all ... its been Superchiped since I got it .. which proves more horsepower/torque that the stock tune, and makes it much faster off the line, giving you a choice of performance tunes, with an economy and towing tune.
Was looking at Tacos before i bought the Frontier .. but I couldnt justify the price points. Its a robust little truck with tons of getup and go.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
