Tree limb damage
If it weren’t for bad luck I’d have n............well you know how it goes.
Spent 5 days at the Big Spring Campground (part of the National Park Service) on the Current River in the Ozark National Scenic Riverways in Missouri last week. On our last night at about 4:30 in the morning I was awaken by a crashing sound and the aframe shaking. At first I thought someone had run into us. I opened the blind on the bubble window over the bed and saw a somewhat large limb laying against the aframe. The pictures show what I saw when I went out to investigate.
No fiber glass is cracked or damaged and the bubble window made it with only some scuff marks. But it did rip a pathway right through the seal.
Has anybody had to replace this seal? I have plenty of the foam seal left over, from a past problem, to do the entire seal 3 or 4 times but have none of the rubber portion which actually is a separate seal.
Thinking about replacing only the damaged portion of the foam seal after squaring it up and just using some good 100 % silicone to piece back the rubber portion that was ripped away. What do you think?
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
