Old 11-21-2015, 10:51 AM   #1
chuck9997's Avatar
Trying to winterize today.
Ok.. I have winterized a few travel trailers. . But this is the first time for my 2014 a122s. I found the low point drains and opened them. I found the bypass around the hot water heater. I bought one if those little kits to put antifreeze in and by pass the fresh water tank. Problem : I found the pump under the sink.. but it's enclosed. Not sure where to put the bypass kit in line.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 11-21-2015, 10:53 AM   #2
chuck9997's Avatar
Here's what it looks like under there.
Old 11-21-2015, 11:02 AM   #3
Remove the enclosure. Kit should connect to pump input side. It is the white hose at front of pump on mine.
mzak is offline   Reply With Quote
Old 11-21-2015, 11:24 AM   #4
bubbles's Avatar
Bummer. You can install the kit at either the holding tank output tubing or the pump input tubing. his is predicated upon them being separated some distance and the most easiest to gain access to. Of course, if they are together and enclosed, good luck.
Old 11-21-2015, 12:27 PM   #5
You will need to remove the front panel facing the door. I would cut a notch in the lower front corner before replacing it to have easy access next year. That is how my 2015 t12rb (same as the a122 I think) came.
kinnikinnick is offline   Reply With Quote
Old 11-21-2015, 12:53 PM   #6
Don't you have an inlet on the side near where city hookup is located?
Mr. Mike 45 is offline   Reply With Quote
Old 11-21-2015, 12:54 PM   #7
chuck9997's Avatar
Ok.. took a wider shot picture. I think this may be the hose from the water tank (if it's under the bed). .. the white one. Would I still need to remove the wooden enclosure?
Old 11-21-2015, 01:01 PM   #8
chuck9997's Avatar
Also.. will the low point drains.. take care of the water heater?
Old 11-21-2015, 01:14 PM   #9
chuck9997's Avatar
Ok. This won't work.. there isn't room to install the cutoff switch without sawing out a big piece of the cabinet and the door. Or moving the pump. How do the geniuses at Rockwood expect you to get antifreeze into the lines.
Old 11-21-2015, 01:34 PM   #10
chuck9997's Avatar
Guess I just can't use this bypass winterizing kit.. I'm not gonna cut big holes in the cabinet and door. I'll just connect the antifreeze bottle manually every year when I winterize. Anyway it is what it is.
winter, winterize
