Old 10-25-2012, 12:42 PM   #1
Undercoat New Rockwood A128S Aframe?
I noticed on my newly purchased Rockwood A128S AFrame that the underside of the trailer is exposed particle board. There appears to be a thin black sealer painted onto the exposed particle board but I was wondering if I should undercoat it more thoroughly. If so, with what product?
Thanks,
neil.ervin is offline   Reply With Quote
Old 10-25-2012, 01:41 PM   #2
I asked the same question in the spring. I had visions of coating the underside with that rubberized truck bed coating. Someone here, maybe d-mo, advised against it. If I recall correctly, it is engineered like that to breath and that adding a coating might void some of the warranty...or something to that effect.
2012 Flagstaff T-12DD
2004 Chevy Suburban
2000 GMC Sierra Z-71
loganmartin is offline   Reply With Quote
Old 10-25-2012, 01:42 PM   #3
Mostly Harmless
thehamguy1's Avatar
That's one of the first things most of us wondered about when we first got our A-frames so you're in good company. The answer is no, because any kind of coating prohibits the floor from drying if/when it gets wet. I think it would also void the warranty.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 10-25-2012, 02:29 PM   #4
yep ... that was me ..
the flooring on these units have a 25 year warrenty .. believe it or not .. and undercoating will definately void it. I cant remember the product name, but i researched it before ...and it needs to breath ...
Anywhooo ... after looking under my unit today (prepping it to be pulled into the garage) its as dry as a bone, and everything is in check, .. and my build date was either december or october of 2010.
Any rot in the flooring will come from unchecked leaks in the windows or siding of these little trailers, and being so small .. these are quickly spotted and sometimes easy to correct.
welcome to the forum .. d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 10-25-2012, 03:26 PM   #5
Thanks to everyone......it is great to have your technical advice. I would not have wanted to void my warranty.
Take care.
a128, a128s
