Old 05-27-2015, 07:20 PM   #1
UTV
Does the A122TH have enough room on the deck for a Polariz RZR 800?
dwjk911 is offline   Reply With Quote
Old 05-28-2015, 04:54 AM   #2
Maybe, but more importantly.......
.........it likely lacks the rated weight capacity to do so.
I believe the only difference between an A122TH and my own A127TH is the interior configuration and the TH platform is identical between the two. Never envisioning hauling more weight than some bikes, firewood, gennie, extra propane, chairs, maybe a couple small dirt bikes, etc, etc, I paid little attention to the TH platform's weight rating, but I faintly recall it's set at 400 lbs.
As to dimensions, it's about 7'6" wide and about 5' 6" front-to-back. The rails which serve as ramps, normally mounted around the perimeter of the platform, could be stowed beneath an ATV or other vehicle to allow for additional length for side-loaded vehicles (but remember that over 8'6" generally requires a permit), so a 50" wide vehicle with a wheelbase of about 7' might theoretically load up, but I think the weight limit kills that idea for pretty much any of the side-by-sides.
Whether I'm correctly recalling the weight capacity or if it is instead 600 lbs, another obvious factor comes into play: Your TH load rests mostly on the hitch, so a lighter-weight TV may struggle to handle the extra tongue weight.
Fox58
Newbie to modern-era small RV camping, but grew up in the 1960s with a Cox tent camper w/ parents and 3 sisters. Yes, a little tight in there.
Rockwood A127TH.
Fox58 is offline   Reply With Quote
Old 05-28-2015, 02:24 PM   #3
handbuilder's Avatar
I have a TH - the cargo deck sticker shows 650 lbs. weight capacity.
I've also looked at UTV however not able to find one that is small enough in measurement to fit on the deck. A small ATV fits and a couple motorcycles fit....I'd be interested to know what UTV you find that fits this deck
ID:	78355   Click image for larger version
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 05-28-2015, 02:32 PM   #4
Poppy94's Avatar
The 800 weighs ~1,000 lbs on average.
Poppy94 is offline   Reply With Quote
