Old 04-06-2014, 02:16 PM   #1
Camping Dude
Dude's Avatar
Wall material ?
Hi to all. Just picked up our new A122S so time for some mods. I would like to mount the dinning table to the wall with
Interlocking channels ( like the grill mount ) and a folding leg. I have all that but my question is what is the wall material made of?
I assume it's foam core if some type. Does any one have any experience mounting anything to the wall as in what type of fastener did you use. I know I can put a bolt all the way through into the storage box on front but that seems like overkill. Any suggestions ?
Dude is offline   Reply With Quote
Old 04-06-2014, 05:34 PM   #2
handbuilder's Avatar
Congrats on your new purchase!
Sounds similar to the mod we plan to do later this summer. We bought the channel rails from Forest River last year but DH just not motivated to do this mod quite yet...
Please share photos of your completed project and any insights when it's all done!!
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 04-06-2014, 08:39 PM   #3
Im not sure about the A122S, but my front walls on the camper sound pretty hollow, if there is anything, watch for the torsion bars.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 04-06-2014, 09:04 PM   #4
The front wall is very thin plywood. It is quire flexible and would in my estimation need significant reinforcement first.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-07-2014, 12:07 PM   #5
Mostly Harmless
thehamguy1's Avatar
The sandwich of the wall is something like one-sixteenth-inch plywood over foam. Through-bolting is probably the best way to go. Another alternative is hollow-wall bolts but I'm not sure the wood is sturdy enough for the load the table is likely to put on it, like when somebody's getting in and out of the seats.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 04-07-2014, 12:55 PM   #6
OutAndAbout's Avatar
I did the same thing you are wonting to do. There are wood studs in this wall, probably plywood. The middle one seams to be about 5-6” wide, the other 2 about 2” wide. You can pick them up with a battery operated stud finder. If you look at the first picture you can see that I mounted a peace of ¼” plywood to these 3 studs. You can see the 3 screws across the bottom of the plywood, there are 3 more just under that curtain thing. They go into 3 wall studs. Before mounting the plywood to the wall first I mounted the wall channel to it. The table is particle board so I mounted a 1x2 cut to length to mount the channel to, as seen in second photo. 3rd photo, finished product.
Hope this helps.
ID:	49292   Click image for larger version
Name:	IMGP0727 smaller.jpg
ID:	49293   Click image for larger version
Name:	IMGP0755 smaller.jpg
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
Old 04-07-2014, 01:43 PM   #7
The is very nice OutAndAbout. I obviously underestimated the strength of the front wall.
Does that stay in the installed position during travel?
Tom
2012 Rockwood A122S
Old 04-07-2014, 01:59 PM   #8
Tom, It can stay up during travel, It's low enough at this location to leave room for the walls to fold down. You can also see that I shortend it about a 3rd. Gave me more room to move around inside. I keep the peace that I cut of in the storage trunk if I ever need the bed.
Thanks for your complement.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 04-07-2014, 03:29 PM   #9
Camping Dude
Dude's Avatar
Great minds think alike! Your setup is just what I had in mind, even shortening the table. Thanks for the info on studs etc, I know someone must have done the hard work first
Old 04-07-2014, 03:42 PM   #10
Camping Dude
Dude's Avatar
Sorry, just one more question for out and about. Do you recall what length screws you used? Don't want to go too far through the wall.
Old 04-07-2014, 04:57 PM   #11
I think the wall is 1" thick, maybe a little more. The length would depend on the thickness of the plywood that you add to bridge between the studs. Can't remeber for sure what I used, 1" but no more than 1 1/4"
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 04-07-2014, 05:10 PM   #12
Camping Dude
Dude's Avatar
Perfect! Thanks for the info
I'll post pix when I get it done
