Water filter bypassed
When I hooked up city water at a recent campsite, I noticed dripping from the camper frame below the city water connection, but not coming from the connection itself, so I shut the water off, went and looked inside, and found the floor all wet. Turned out the connector attaching the water line to the filter had been poorly tightened and had vibrated loose. I've never liked these #@*^ water filters Forest River seems compelled to install inside their campers, so I just cut the Pex on each side of the filter, took the filter out, and re- connected the lines with two Pex connectors and a braided water line. Outside of having to mop up the water, it's about the simplest fix I've ever done. I hate those filters. They're nothing but trouble and, half the time, they're located in a place where it takes a contortionist to get at them to change the filters and mop up all the water that comes out when you try to do it.
Kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
