Old 08-20-2015, 10:03 PM   #1
PegKen's Avatar
Washing roof of A-frame?
I ordered RV Gel Wash to clean the exterior of my A-frame. I assume that the A-frame should be popped up for washing. (Or not?) What do folks use to reach the peaks? Or is it better to collapse the A-frame down when washing it?
Thanks for any and all tips!
PegKen
PegKen is offline   Reply With Quote
Old 08-21-2015, 06:24 AM   #2
I open my camper up and use a painter's extension pole with a long handle brush attached. I buy Turtle Wax that comes in a gallon jug...pour a small amount in a bucket...fill with water and wash away. Works great and no water spots later.
David
Tow Vehicle: 2012 Durango 3.6 Pentastar Engine
Total nights camping 2014-(10)
Total Nights Camping 2015-(9)
Total Nights Camping 2016-(5)
Total Nights Camping 2017-(4)
Total Nights Camping 2018-(7)
mlsa3 is offline   Reply With Quote
Old 08-21-2015, 02:43 PM   #3
I used diluted Simple Green, and wash the windows very carefully with a cotton cloth/lots of water as they scratch easily. I have a long handled soft brush meant for this type of washing, guaranteed not to scratch finish, works great. At times, if it sits too long, I have to hand wash areas where the Norfolk island pine sprays it during the Spring with sap, even under the carport, darn it!
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 08-21-2015, 02:57 PM   #4
simple green will damage your bubble lights .. so please do not use it ...
I clean the Aframe with the roof closed .... use RV wash and wax ... and all is good. if i have some very subborn stains i use RV black streak remover .. but that has not happen very often.
I do not wash when the unit is up .. as i have had some leaking problems ... but i was a newbie at this .. spraying water all up inside the foam panels and stuff ... just a note .. dont bother doing this .. saves you lots of headaches ... \
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 08-21-2015, 03:02 PM   #5
Thanks for the heads up on Simple Green. I use mostly water except for the tree sap. So far, no problem with the windows, but they sure are a worry. Guess I will have to break down and spend money on the RV stuff to be safe, what's a little more money!
Old 08-21-2015, 05:17 PM   #6
DanM-AZ's Avatar
Telescoping car wash pole
I use something like this:
Detailer's Choice 4B369 Flow-Thru Vehicle Wash Brush with 60" Telescoping Handle - Walmart.com
Roof erected, Meguiar's Deep Crystal car washing soap in a bucket, just like I would do to wash my truck. The pole just needs to be extended longer.
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 08-21-2015, 09:15 PM   #7
handbuilder's Avatar
I wash mine with the roof up. I use a long handled pole with a soft cloth type of mop brush at the other end (for motorhome washing). I've never had water enter the unit when washing. I am also careful not to shoot water up the sides. I stand on the ladder and spray it parallel and down.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 08-22-2015, 11:43 AM   #8
I parked my pick up under Chinese Elm don't leave that on will ruin paint job.
Myrle is offline   Reply With Quote
Old 08-22-2015, 07:26 PM   #9
PegKen's Avatar
I parked mine under some oak, beech, and maple trees. The wet leaves have left stains. I also found small, brown ants crawling on the exterior. I'm assuming that they fell out of the trees because I sprayed all around the perimeter of the camper with bug spray. (Unless the rain washed all of the spray away, too!)
PegKen
Old 08-23-2015, 05:48 PM   #10
I washed the camper closed up today with RV gel wash/wax and it looks great, but I always see a slight haze on the bubble windows no matter what I use. What is safe to restore them to that nice black shine?
a-frame, frame, roo, roof
