Old 05-04-2016, 01:26 PM   #21
kdot's Avatar
Water Filter Cannister
Scott, it's hard to believe some of the things that happen in the manufacturing process. My A213HW was delivered to me with a regular water hose draped across the underside to provide toilet flush, -no zip ties to the frame or anything. After a lot of trouble with leakage, the dealer replaced it with PEX on warranty. Haven't tried it yet, keeping fingers crossed.
We had a Palomino Gazelle some time back that blew pieces of styrofoam insulation all over the place when we turned on the AC. I talked to a guy in a 5th wheel camped across from me in Florida. He said he has the same problem and it's been going on for two years.
Kdot
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 05-06-2016, 10:17 AM   #22
After reading about the pressure reducing effects of the filter, I pulled the dealer installed filter from the housing. Then I had much better flow. Teh downside of the empty canister is air accumulation at the top of the housing that then get drawn into the water flow. So I replace the housing with a "Handbuilder filter" and reclaimed the space in my cabinet.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-06-2016, 01:25 PM   #23
Dodge Guy's Avatar
I'll only put a filter in there if I know I'll be using my freshwater tank frequently. This year I won't use one as all our stops are FHU. Next year we'll be going to Yellowstone, and I expect a bunch of no hookup stops so I'll be using the fresh water tank. When o don't use he tank I use an in line filter.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 05-12-2016, 12:45 PM   #24
Replaced KW1 Canister
I couldn't bring myself to buying a $30 filter that only fits the KW1 housing so I installed a housing that takes standard everyday filters.
Robot Check
Having said that, I have the original KW1 housing for sale. Removed from my 2014 camper in like new shape. Can provide photos to anyone interested.
TV- F150 FX4
TT- MicroLite 23FB
Tent2TT is offline   Reply With Quote
Old 05-12-2016, 12:47 PM   #25
TURBS's Avatar
My dealer sells them for $23.00
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-12-2016, 01:21 PM   #26
I found this filter at FreshWaterSystems. com
Works great and a lot less KX Matrikx CTO 5" Carbon Block Filter 5 Mic $8.95
JPBar is offline   Reply With Quote
water, water filter
