Old 08-16-2015, 09:35 AM   #1
PegKen's Avatar
Water from sink?
New to camping here: how do you handle water going down the sink drain when camping at National or State Parks with no services?
PegKen is offline   Reply With Quote
Old 08-16-2015, 09:36 AM   #2
340_Formula_S's Avatar
Most of them have a central dump station. I carry a tote tank with me just in case I need to drain a tank.
Elko, Va.
2012 Ram 3500 DRW Cummins High Output
2012 Cedar Creek 36B2
340_Formula_S is offline   Reply With Quote
Old 08-16-2015, 09:51 AM   #3
PegKen's Avatar
I don't think the Rockwood Hardsides have holding tanks. At least, the manual doesn't talk about one.
Old 08-16-2015, 09:57 AM   #4
You can place the tote tank outside the camper and hook to it for you holding capacity and dump when it's full. Look on Amazon, they have a great selection. Key search is RV tote tank.
Elko, Va.
Old 08-16-2015, 10:37 AM   #5
trailergirl99's Avatar
Do a search for "Grey Water Set up" (I'm on my phone and can't link to it).
That's how I leaned how to do it and ordered an adapter suggested. It works perfect, but does drain a little slow. Others have set up something more complicated but I use so little water inside that this works for me.
2015 Rockwood A122s
2015 Jeep Grand Cherokee
trailergirl99 is offline   Reply With Quote
Old 08-16-2015, 11:19 AM   #6
I have a portable grey water tank with two wheels with a removable metal hook that fits the tow ball on my tow vehicle. When almost full I wheel it to the car, hook it up and very slowly/ 5 mph drive it to the dump area. I stow it inside the camper when I travel, so can pull it out first for setup.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 08-17-2015, 11:57 AM   #7
Use a 7 gallon aquatainer, Unless you do dish washing inside, it will do for a weekend with careful use.
The photo is from Ozandus of a Fleetwood popup.
The setup can be simpler with a garden hose. The aquatainer cap has a 3/4 FPT opening, so get a plastic adapter, 3/4 MPT to 3/4 MHT. You should have received an adapter to attach a hose to the 1.5 inch MPT outlet on the camper. If you don't have one they are pretty cheap.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-17-2015, 07:14 PM   #8
This is what we do.
2015 A122S
CJofWolfcreek is offline   Reply With Quote
Old 09-02-2015, 05:07 AM   #9
chuck9997's Avatar
Could someone find the adapter for attaching a hose to the 1.5 inch MPT outlet. .. and post a link. So I know exactly what I need to buy. My used a122s didn't have the adapter.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 09-02-2015, 05:13 AM   #10
chuck9997's Avatar
Nevermind. .. think I found what I need.. here: http://www.amazon.com/Valterra-T01-0.../dp/B0006MTREC
water
