Old 04-24-2015, 07:21 AM   #11
TURBS's Avatar
Originally Posted by Pooneil View Post
The detector alarm will sound on low voltage. So what you are describing could be an electrical problem. The water pump does have a heavy current draw and its possible that tin conjunction with a poor wire connection, the voltage could drop. Take an unopened digital multi-meter along just in case. If you don't need to use the meter, then return it to the store.
Just keep the multi meter in the camper you'll need it it again .
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-24-2015, 07:57 AM   #12
mikeandclay's Avatar
Originally Posted by TURBS View Post
Is your battery about dead?
TURBS
That's what I'm thinking... It's flashing red and green which says its low voltage. Any idea of how to silence it so I don't go mad!?
mikeandclay is offline   Reply With Quote
gas, heater, water, water heater
