Old 10-07-2015, 07:00 PM   #1
chuck9997's Avatar
Water Heater Bypass
Does anyone know. . On a 2014 Rockwood a122s.. how do you bypass the water heater when you winterize? And... how do you pump the antifreeze into the line? On my old travel trailer i bought one those pump converter winterizing kits.
Or do you just blow air through the line?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 10-07-2015, 07:47 PM   #2
cheriesgeek's Avatar
Under the driver side dinette bench, you will find the water heater and bypass line. My cover came with a screw in it. I plan to drain my 2015 a122s and then blow it out with low pressure air.
Jay
2015 A122S and 2011 Work and Play WR30
2005 F-150 SuperCrew, 5.4L, tow package, 3.73 axle
2011 F-350 SuperCrew, 6.7L, FX4, 4x4, DRW, tow package, 3.55 axle
cheriesgeek is offline   Reply With Quote
Old 10-07-2015, 07:48 PM   #3
chuck9997's Avatar
Just blowing out.. no pink stuff?
Old 10-07-2015, 08:01 PM   #4
That is the plan. I have run the pink stuff through other systems in the past followed with air. With the low point drains on my camper, I am willing to forgo the pink stuff.
Jay
Old 10-07-2015, 08:04 PM   #5
chuck9997's Avatar
I think I would go with just air too.. but I would have to buy an air compressor. . Pink stuff is cheaper.
bypass, heater, water, water heater
