09-06-2016, 08:43 PM
Water Heater Help - Rockwood A192HW A-Frame
Newbie here . . . I have only been a camper for less than one year. We have a Rockwood A192HW A-frame camper which we love. We travel with other family and rarely if ever need hot water as my son and family usually do all the cooking and we use the campground restrooms for showers. Our camper has the Suburban SW6D water heater which runs on propane only and I have a few questions on use and care. How do I fill the hot water tank if we are hooked up to the water supply at the campground? Do i need to keep water in the tank if we are not using hot water or just keep it empty? Any other advice or maintenance tips would be greatly appreciated. Thanks!
2016 Rockwood A192HW A-Frame
2015 Chevy Silverado
09-06-2016, 11:03 PM
The way the plumbing is designed is that your water heater will fill up automatically if you are hooked up to a pressurized water connection through your outside city water connection.
The other way is through your fresh water tank and water pump. Once you fill your fresh water tank and turn on your water pump, your water heater will fill up.
You then make sure that your propane tank valve is open and turn on your water heater switch. After a few seconds, you should hear the water heater turn on. It will take about 20 minutes or so to heat the water up.
Many RVers empty their water heater when they get home if they will not be camping for a while, so that water is not just sitting there stagnating for weeks or months. The water heater is emptied by opening the pressure relief valve on the outside top of the heater and then removing the drain plug which is on the outside bottom. You probably have an anode rod attached to the drain plug, which is designed to slowly wear down as it protects the water tank.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
09-07-2016, 04:40 AM
Thanks for the great information. I appreciate your time.
09-07-2016, 04:49 AM
If you are using the hot water heater every month or so many of us only drain the tank to winterize once a season.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-07-2016, 07:16 AM
Water Heater help
What Oaklevel said.
Kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
09-07-2016, 07:56 AM
As an additional sidebar, once you turn on the city water or pump, open the water faucets and bleed the air out of the lines and this will allow the WH to fill. Do this BEFORE turning on the WH. Some will use the pressure relief valve on the WH to bleed the air, I don't myself, just be sure to turn on a hot faucet at least untill you have good flow of water
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
09-07-2016, 08:14 AM
Just a thought. If you've never used the water heater before, it may still be bypassed with the winterization valves.
Before starting it up (which I would do just to make sure it works) check the bypass valves and open the P&T (pressure relief) valve. that makes sure there's water in the heater.
Gotta go campin!
09-07-2016, 06:56 PM
wh use
If you get into a cg that uses well water as a source that has high minerals make sure to drain the hw heater. The aluminum tank will react to the minerals in the water and the water will turn blackish and smell like sulfur.
09-07-2016, 07:13 PM
Canadian Member
The water heater should have a pressure relief valve at the top behind the outside cover. The best way to confirm that the water heater tank is full is to open the pressure relief valve by lifting the lever and wait for water to come out. That way you know it's filled and the air can escape allowing the tank to fill. You won't get much water out of the taps while the water heater tank is filling.
09-07-2016, 08:10 PM
I pull the low water drains and open the faucets on the outside shower at the end of a trip to let the system drain. This apparently won't fully drain the HW tank but it will get most of the water out of the system. It is enough for me as I don't winterize. I usually open the fresh water tank drain too and allow the tank to empty as much as it can.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
09-14-2016, 07:05 AM
If I do not want to use hot water can I just prevent the water from filling the tank. Would I close the valve on the cold water side and close the valve on the crossover side. Then I would not fill the tank when I use the city water as my water source, right and would not have to drain the tank.
09-14-2016, 08:35 AM
The water heater should have a bypass kit installed. Take off the bench cover and turn the valves to bypass the WH. It won't fill until you reverse the valves.
Tom
2012 Rockwood A122S
09-24-2016, 10:28 AM
World Traveler Member
I just turn on the hot water valve on the sink or outside shower valve to bleed air and verify water in the hot water tank. I do not turn on the hot water heater unless to check or use. I have noticed on my A194HW that with the water pump on I get better flow with both handles on the sink on at the same time.
2014 A194HW
2004 Toyota 4runner V8 4WD
09-24-2016, 11:03 AM
The issue with turning on a faucet to see if the heater is full of water, is that if the bypass valve(s) is set to the winterize position you'll get water out of the faucet, but the heater tank will be empty. So if you accidentally forgot to dewinterize the tank will be empty. That's why we always recommend opening the T&P (pop off) valve.
Gotta go campin!
09-24-2016, 11:10 AM
X2, and it's also explained further here:
http://www.forestriverforums.com/for...tml#post327988
2011 Flagstaff 831 RLBSS
09-24-2016, 12:05 PM
I guess I am lucky I live in California where it never really freezes for long and I never have to turn the valve off.
2014 A194HW
